Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Top End
Last Post: andy2175m4
0 Carb ???
0 2021 Iron Butt Rally
0 Mainshaft Oil Seal Leak
0 Indicators not flashing
0 It's Glamazon's Birthday!
Last Post: Veeflys
0 First start question
Last Post: 72HOGXLCH
0 HSR idle mixture screw
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: handa700
Old 28th May 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Originally Posted by Sprtstr1200s View Post
I don't know what shape my springs are in. Haven't opened the motor yet.
Your stock ones were just weaker to begin with. Fine til you start putting cams in.
Old 28th May 2019
Sprtstr1200s's Avatar
Sprtstr1200s Sprtstr1200s is offline
Sportster/Buell Model: Sportster XL1200s
Sprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond repute
Spent an weekend screwing around testing springs, new, old. Amazed at the variations. https://www.bing.com/images/search?q...ster&FORM=IGRE
Old 29th May 2019
ParrotHead's Avatar
Other Motorcycle Year: 1974
Probably not necessary especially if you dont disturb the cylinders. If you do it means means pulling at least 1 wrist pin clip per and the wrist pins. Leave the pistons in the cylinders or you're doing rings.
I'd try getting the broken studs out without removing the heads first.
Rather hard in my opinion to not disturb the cylinder when pulling the heads. I didn't do mine and developed a base gasket leak so I had to pull everything to simply replace the base gasket.
I never removed the wrist pins, I was able to slip a ring compressor over the piston and slide the cylinder over the piston and rings.
John Wayne - "The Shootist"
Click here
to listen to my interview on the Chasing the Horizon Podcast
Old 29th May 2019
60Gunner's Avatar
When I pulled my heads, my front cylinder stayed stuck down even tapping the head loose. Had to hit the cylinder several times to break it loose once I decided to pull it.
A local Indy that does machine work for the dealership too says broke loose or not, he just torques them back down and never had one leak. Mostly the old stock ones that use the oring I think.
I know Hammer has reused the mls gaskets too. Base and head. I reused them recently myself. Pulled the heads and retorqued with the same mls base gaskets.
I ended up going with a 1250 and never did bolt the old paper ones back down. Fortunately all the old gasket material came with the old cylinders. Have fun cleaning them off the cylinders to replace. The paper base gasket is a biotch to get off.
Old 29th May 2019
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Originally Posted by herostar View Post
Hello everyone!
I had two exhaust studs break off, one in each cylinder head, so I'm going to need to remove the heads to get the broken studs extracted/replaced at a machines shop.
My question for you all: What else should I be doing while the heads are off? I'm not looking to go deep porting/polishing or anything, but am curious if there are "normal" maintenance things I should take care of while everything is off the bike.
FYI this is for a 2003 XB9R
Thanks in advance for your help!
If you get the proper tool for drilling out the studs, you don't need to pull the heads. I think you'll be surprised how easy it is. Just go through the procedure for rotating the motor down, which is described in the service manual. You'll have enough access to do the job.
My advise is don't even waste your time trying to unscrew the old studs. They're going to be stuck in there like you can't believe and the chances of unscrewing one are slim. The studs are an interference fit thread on the head side. That means they're designed to bind up in there, and they do a mighty fine job, too, especially after 16 years of being heat cycled. Not to say it's never been done, but it's just unlikely you're going to unscrew a broken off stud.
And whatever you do, don't let an easy-out get within 10 feet of your bike. I can't begin to tell you how many heads have come into the shop with a broken off easy out embedded in an exhaust stud. Now the only cure is carbide end mills, which are expensive and easily broken. An easy-out has about a .0001% chance of unscrewing that stud and a 99.9999% chance of breaking off. Don't go there.
Here's what you want:
The drill jig works slick as hell. It sits in the pocket where the exhaust gasket goes, that aligns it. You use the good stud to bolt it down. Now you just drill with a 1/4" drill bit. The jig makes it go straight through the stud. When you're done drilling, you'll have a hollowed-out shell of the stud left in the head, but it generally comes out pretty easy. Often you can do the whole job with little to no damage to the threads in the head. Just remove the hollowed out stud and screw in a new one. Maybe chase it with a tap first.
I suggest replacing it with the factory stud, because aftermarket ones don't have an interference fit thread on the head side. The interference fit thread is what keeps it from coming out of the head when you remove the exhaust. Loctite red isn't going to be effective there, it's too hot.
You may be able to find other brands of this drill fixture cheaper than the above, too, maybe someone will chime in with a link.
The reason the studs break is partly because they get fatigued over the years, but also because of exhaust mounting issues. To the extent the exhaust is allowed to move independently of the motor, it's flexing those connections to the heads. Often a poorly mounted exhaust will cause the nuts to loosen up from this flexing. I've seen guys use locking nuts to keep them on, but that's treating the symptom, and really just making it more likely to break a stud. The root cause of the issue is the exhaust mounting to the motor.
Back in the tube frame days, this was just a terrible issue on Buells. Buell finally came out with an updated mount - the one that attaches the front of the muffler to the motor - that was considerably stiffer. This about 90% fixed the issue, failures became much more rare.
Click Here to Contact Me
Old 30th May 2019
ParrotHead's Avatar
Ok, dumb question. Once you have the hollowed out stud how do you remove it?
Old 30th May 2019
shanneba shanneba is online now
"Clear out remaining pieces of stud by running a 5/16 x 18 tap through hole to restore threads."
https://img.jpcycles.com/staticwebfi...df/440-266.PDF
2013 XL1200C
Find your Owner's Manual, Wiring Diagram and Parts Catalog here :
Enter your VIN OR
SportsterPedia.com
Old 4th June 2019
herostar herostar is offline
Sportster/Buell Model #2: XB9R
herostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really nice
This is great info, thanks to all of you who have contributed. I'll post back once some progress is made to let you know how things work out.
2007 XL1200R - Denver, CO
