Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Electrical and Ignition
0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Fifty150
0 Off Road Lights
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 HSR idle mixture screw
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
0 Front deflection
Last Post: denguy
Last Post: Fivecats
0 Ran out of gas.
Last Post: Hellbent_4
0 Best seat for long rides
Last Post: Diogenes415
0 need help with 68 XLH
0 2021 Iron Butt Rally
Old 10th May 2020
Rlandry1988 Rlandry1988 is offline
Sportster/Buell Model: Thunderbolt s3
Sportster/Buell Year: 99
Rlandry1988 is an unknown quantity at this point
Default No power!!! Please help
So i went to make a minor adjustment on my idle speed with idle screw while bike was running and accidentally touched the metal part of my screw drive to something metal and the bike shut off. Turned key off and back on and now i dont have the neutral light, oil light or check engine light displayed when turning key on. Also do not hear fuel pump kick on either. Ive replaced main circuit (30amp) under seat above battery.
Old 10th May 2020
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
You won’t have a fuel pump with a carb. Sounds like you need a service manual and the troubleshooting guide.
Are there fuses on a ‘99??
Old 10th May 2020
https://m.youtube.com/watch?v=QrWk_Av_KMw
Old 11th May 2020
Thought something didnt sound right while i was typing the post initially iron mike. But yes im trying to diagnose it but im At a hault. I have checked all fuses and cant find diagram of engine components so i can see actually what Part it is that i touched the screwdriver to.
Old 11th May 2020
There may be other fuses on that '99. I'm not so familiar with the Buell chassis, but I am running two of those throttle bodies on an Ironhead. I would not think there is much power in the area you were adjusting other than the Throttle Pos sensor. Try to google where all the fuses are located until you get your hands on a manual. i did a quick search and says there is a main fuse near the battery. Perhaps that is the one you changed. There is probably more than one.
Googling wire diagram may yeild some info as well.
Old 12th May 2020
gusm2's Avatar
gusm2 gusm2 is offline
Sportster/Buell Model: Cyclone M2
Other Motorcycle Model: Suzuki SV650
Other Motorcycle Year: 01
gusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud of
Did you short against the battery, otherwise touching the carb with a screwdriver would make no difference ?
10.93@119.9
Old 12th May 2020
gusm2's Avatar
I'd recheck all the fuses
Old 12th May 2020
Highly-Dangerous's Avatar
This Thread is repeated.
[B][COLOR="Red"]CLICK->>[/COLOR][URL="http://sportsterpedia.com/doku.php/start"]"Maintenance is as much art as it is science"[/URL][COLOR="red"]<<-CLICK[/COLOR][/B]
[IMG]http://xlforum.net/forums/attachment.php?attachmentid=20617&d=1576580635[/IMG]
Old 12th May 2020
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Sorted: merged the threads.
Folkie
South East England Riders
