5 Rethinking 1250 Build
1 Buy your New iPhone 13/ 13 Mini/ 13 Pro/ 13 Pro Max in Bulk and good price
Last Post: sinikbab22
0 Exhaust question
0 Timing, static or strobe?
0 Starter Relay?
0 First start question
Last Post: Jaime1840
Last Post: xena
Last Post: Andy56
0 33.4mm fork bushings
Last Post: 4cam
0 help with stuck engine
0 1988 1200. Unable to get oil pressure. New pump, new filter, new pipes, new oil.
caliper frozen, stuck brake pedal
Old 8th December 2020
Encyber Encyber is offline
Sportster/Buell Year #2: 2005
Encyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of light
Default 05 Sportster 1200c brake pedal frozen
Drive home from work was uneventful until about two blocks from house when the rear brake pedal suddenly quit working. Pedal won't depress. Stuck in disengaged position so no brake drag. Visual inspection shows nothing obviously wrong. Brake pads and master cylinder rebuilt maybe 3500 miles ago. Working perfectly until now. Florida bike, garage kept. Fluid levels fine. Dot 5.
Thinking Caliper just a little stuck. Is that common?
"Pedal won't depress" - Does the brake light come on?
If the caliper is stuck, I would expect the brake light to work because you are pressurizing the line.
On the other hand, if the brake light does not work, then I would suspect the MC is the problem because the line is not being pressurized.
motorfish's Avatar
motorfish motorfish is offline
Sportster/Buell Year: 2012
Other Motorcycle Model: Road Glide CVO
Other Motorcycle Year: 2009
motorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond repute
Did you replace the stock DOT 3 or 4 by DOT 5?
That can be the source of your problem, DOT 5 will cause the seals (meant for DOT 3/4) to swell and disintegrate in the long run.
Proper replacement or upgrade to DOT 3/4 is DOT 5.1, not silicone based DOT 5.
Thumbs up Think it's fixed
Thanks IXL and Motorfish. That's great feedback. Good to know next time something similar happens. As it turns out, while waiting for a reply I pulled the brake pads, sprayed brake cleaner on the caliper and piston and pushed the piston in gently with a C-clamp. It was pretty stiff but when I put it all together again and took it for a spin, the pedal freed up and now the rear brakes appear to be functioning normally....for now perhaps.
Motorfish, not sure why I mentioned Dot 5. That's what the bike specs. Guess I just wanted to provide as much info as possible.
Thanks again for the quick response, guys. It's why I love this site.
Ride safe!
Old 10th December 2020
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
2005 was still DOT 5, they did not switch back to DOT 4 until 2007.
