0 Carb ???
0 2021 Iron Butt Rally
0 Mainshaft Oil Seal Leak
0 Indicators not flashing
0 It's Glamazon's Birthday!
Last Post: Veeflys
0 First start question
Last Post: 72HOGXLCH
Last Post: andy2175m4
0 HSR idle mixture screw
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: handa700
'90, shocks, tires
Old 15th January 2021
Rollbar's Avatar
Rollbar Rollbar is offline
Sportster/Buell Year: 1990
Rollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud of
Originally Posted by xHDrider View Post
I run the optional bigger metzler me 880 tires
i use road king air shocks short ones in the 11 inch range same lenght as my stock shocks eye to eye. i use a little harley air pump.
i ride with about 2 psi alone an with a buddy about 12-15 psi more user friendly then a spanner wrench
also have progressive front fork springs, if you ever rode with a front fork brace you wouldnt was to ride with out one (just figured i would throw that in)
Ok great information.
I was looking at those front braces but in Florida losing the front fender might not be an option even if I chopped it down some. But I have really thought about those braces and if they are that good, well,,,,,,,,,,
Thanks again.
rwharris's Avatar
rwharris rwharris is offline
rwharris is an unknown quantity at this point
Going down from a 48 to a 47 rear sprocket only lowers your rpm by 50rpm. 22-47 at 75mph =3750rpm. I have the belt drive conversion on my 90 and at 65mph I am reving 3300rpm and at 75 = 3950 rpm. I have no options to change gearing. I also have a fork brace( screaming eagle) fits with fender on. I sent you a PM. Roger
Rollbar's Avatar
Ya I ordered a 46 tooth for the rear and I have a 22 tooth for the front.
4spd so I should be ok and might just have to cruise around the back streets in 3rd gear.
We will see how that works but before I put it on, I'm gonna do some calculations.
Wanted to have it so I can do it at the same time as the tire etc.
Rollbar's Avatar
Originally Posted by Rollbar View Post
Here is my bike.
When I bought this bike the POwner painted a lot of it flat black w/grill paint seems like.
Question regarding the mags/Rims.
Did they come black like that it were they all aluminum looking?
The spokes (if you want to call it that) sides were also black and I took a Scotch-Brite pad and made the sides of the spokes to look like aluminum to break up all the black.
Thanks again,
cal43's Avatar
cal43 cal43 is offline
if you search for a real motobiketire and not a chopper/cruiser everlast, search for Bridgestone BT-45
Rollbar's Avatar
Ok thanks,
Old 20th January 2021
sportymike02's Avatar
Sportster/Buell Model: 1200c
Sportster/Buell Year #2: 1979
sportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond repute
Thanks again.
A fork brace and Metzler tires made it seem like a different bike. steady in the curves and no wandering over milled roads or steel grate bridges
John Harper's Avatar
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
Pirelli Night Dragons if they are still made. Stick like glue.
https://www.pirelli.com/tyres/en-ww/...t/night-dragon
John
Rollbar's Avatar
John
Thank you
Rollbar's Avatar
Good info,
Thanks
