5 Rethinking 1250 Build
Last Post: LoneWoof
0 First start question
Last Post: Jaime1840
1 Buy your New iPhone 13/ 13 Mini/ 13 Pro/ 13 Pro Max in Bulk and good price
Last Post: sinikbab22
0 Exhaust question
0 Timing, static or strobe?
0 Starter Relay?
Last Post: xena
Last Post: Andy56
0 33.4mm fork bushings
Last Post: 4cam
0 help with stuck engine
0 1988 1200. Unable to get oil pressure. New pump, new filter, new pipes, new oil.
ironhead, oil dipstick, oil level
Old 2nd March 2021
ThenCameHarry's Avatar
ThenCameHarry ThenCameHarry is offline
Sportster/Buell Model: XLS
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1999
Other Motorcycle Model: 2 Ironheads XLH
Other Motorcycle Year: 1979
ThenCameHarry has disabled reputation
Originally Posted by Andy Hog View Post
On my 81 I put the bike in the upright position, as if I was sitting on it, fill the oil tank to the bottom of the neck on the filler spout, this gives the correct amount. I do it with the engine cold.
Hopes this helps.
Thank you Andy for your post.
Yes, your post indeed did help.
See my previous reply.
Thanks again for your help.
Much appreciated.
Harry
Old 2nd March 2021
The 79 oil tank is a one year only mistake where someone calling himself a MC Designer decided that the oil fill must be hidden. To accomplish this travesty the filler neck was lowered over 1".
80 fixed the filler location. (And probably holds a quart more oil)
Harley oil levels must be checked hot, a cold motor may be full of oil, showing an artificially low oil level in the tank.
Old 2nd March 2021
Sportster/Buell Year #2: '03
they should come with a sticker on the oil tank with that message.
Old 2nd March 2021
How about that. I have always wondered why the filler cap on the 79 was hidden.
Anyway, thanks Rick for your reply.
Earlier today I topped off the oil level to upper mark on the dip stick with the bike hot and upright.
Then indeed when cold the tank oil level seems indeed to be somewhat low.
Thanks again.
Harry
