0 Carb ???
0 2021 Iron Butt Rally
0 Mainshaft Oil Seal Leak
0 Indicators not flashing
0 It's Glamazon's Birthday!
Last Post: Veeflys
0 First start question
Last Post: 72HOGXLCH
Last Post: andy2175m4
0 HSR idle mixture screw
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: handa700
larger tires, tire clearance, tire size, tires
Old 26th March 2021
Jarlaxle Jarlaxle is offline
Sportster/Buell Model: XL883L bagster
Jarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant futureJarlaxle has a brilliant future
Default Tire clearance
I have a no longer Super Low 2011 883L, raised with Tracker Die damper rods and bagger shocks. It needs a rear tire soon, and the selection is pitiful. I also want to kill a few RPMs...so I want to go a bit larger than the 150/60R17. I know a 150/70 fits (it's oem on the 1200T), but that selection is even worse for radials. So, my question: will a 160 or 170/70R17 tire clear the belt and swing arm on a rubber-mount Sporty?
Loud pipes lose rights.
Old 26th March 2021
sportsterdoc's Avatar
How much clearance do you have with the 150 mm tire?
Old 26th March 2021
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Originally Posted by Jarlaxle View Post
...So, my question: will a 160 or 170/70R17 tire clear the belt and swing arm on a rubber-mount Sporty?
I have the 17" rear / 18" front Superlow wheels on my '17 Custom.
A 160/70-17 T31 or T32 Bridgestone will fit easily and is meant for the 4.5" wide rim. I'm running a 160/60-17 T31.
Old 26th March 2021
sml1226 sml1226 is offline
Sportster/Buell Model: XL1275R
I've got a 160/70-17 Michelin Pilot Power 2CT on there with no issues. 1-1/8" belt too. Not sure if the 1" belts track further from the wheel, but I can't see them being closer.
I think I might be able to get a 170 on there, but the selection for 160/70-17s is pretty solid. Doesn't explode into abundance until you hit 180/190 width tires anyway.
Old 28th March 2021
Cool! Those tires radials?
Awesome. Looks like I'm going 160/70R17.
Old 28th March 2021
Dazed & Confused
Yes, tubeless radials.
