Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Top End
0 Carb ???
0 2021 Iron Butt Rally
0 Mainshaft Oil Seal Leak
0 Indicators not flashing
0 It's Glamazon's Birthday!
Last Post: Veeflys
0 First start question
Last Post: 72HOGXLCH
Last Post: andy2175m4
0 HSR idle mixture screw
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: handa700
Old 14th May 2021
TPEHAK TPEHAK is offline
Sportster/Buell Model: 2009 Buell XB12Scg
TPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud of
Default Cylinder base oil leak fix with pig tails for Buell XB ?
Hello. I have a question about the cylinder head pig tails people install on the base of the cylinder to permanently fix the cylinder base gasket leak
According the information I found those tube pig tails fit 1995-2002 S2, S1, S3, M2, X1 Buells and Harley Davidson EVO BT & XL Models.
So my question is do these pig tail tubes work for 2009 Buell XB12 engine?
https://st-paul-harley-davidson-buel...9d16f692&_ss=r
http://www.badweatherbikers.com/buel...23/804303.html
Old 14th May 2021
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
I haven't personally used them on XB's, but there's no reason they shouldn't work. The XB cylinder is the same as a Sportster cylinder.
Click Here to Contact Me
Old 8th August 2021
OK, I have successfully installed the pig tails on 2009 Buell XB cylinders. More info here http://www.badweatherbikers.com/buel...tml?1628182061
