Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Top End
0 Lurker from the SF Bay Area
5 Rethinking 1250 Build
Last Post: lehel
Last Post: mrmom9r
0 Electrical almost all sorted
Last Post: Andy Hog
0 So Long
Last Post: XL Ed
Last Post: xena
0 The Beat Wife
Last Post: Fifty150
Last Post: skien
Last Post: 73HEAD
Last Post: cazz1000
Last Post: jcro61
0 First start question
Last Post: MikeBel
0 Should I buy a Sportster??
0 Exhaust question
Last Post: Monte03
0 Bassani Baffle Supplier
doughboy (68), tinman (66), mofo (59), JAFI (58), Topgun (56), Hogwylde (56), Pay Toilet (55), grwhite038 (53), JWG883 (52), sorryifitburns (48), Leibniz (46), higgins14 (44)
Old 8th August 2021
TPEHAK TPEHAK is offline
Sportster/Buell Model: 2009 Buell XB12Scg
TPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud of
Default 2009 Buell XB12 engine top end CAD model
I have reverse engineered the 2009 Buell XB12 engine top end. Here is the CAD model
https://grabcad.com/library/2009-bue...gine-top-end-1
This is precisely and completely reverse engineered top end of 2009 Buell XB12 engine with ALL internal components. The models were built using a 3D scanner and metrology tools. Mating surfaces tolerances are +/- 0.01mm. Non mating surfaces tolerances are +/- 0.15 mm.
This model can serve mechanical engineering needs like designing engine modifications, CNC porting of the intake and the exhaust, laying up turbo setup, designing custom parts, cylinders boring, squish band checking, using for parts fitment sizes reference, etc. This CAD model assembly file has correct components part numbers in the components names and can be used as reference for looking for parts for the engine service.
You also can use the interactive 3D model of the Buell XB engine on the GrabCAD to find the part number of the component you need just simply clicking on it in the 3D view in you web-browser. No need to use the parts catalog anymore!
Old 8th August 2021
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Very cool!
Tel me about that scanner. Brand/model?
Click Here to Contact Me
Old 8th August 2021
The scanner is Next Engine 3D scanner.
http://www.nextengine.com
I do not recommend this scanner for precise reverse engineering work and for big parts, it is extremely slow and painful to scan with it and to process the 3D scans with this scanner, it requires a lot of preparation work prior to scanning and special processing technique to have acceptable result. And the result is not very accurate, especially for big parts. I use it just for reference to see the geometry while creating the CAD model, I did the most work measuring the parts manually with different measuring tools.
I have access only to this 3D scanner so I had no choice, it is better than nothing for some parts. Decent, fast and easy to use 3D scanner is very expensive tool. I would love to have better scanner.
Old 8th August 2021
Hippysmack's Avatar
I don't know what to say but DAMN THAT'S BADASS!!!!!!!!
I'm humbled.. And you've been busy.
Old 8th August 2021
Hippysmack's Avatar
Very cool!
What's that I smell.... Is that case batter cooking on an open fire?
It'd be cool if you guys could do something with this technology.
It's way over my head but there is a lot of potential there for obsolete parts?
Old 8th August 2021
rejeanprimeau's Avatar
3D printing bad a.. heads ???
Old 8th August 2021
kitabel kitabel is offline
Sportster/Buell Year: 1989
CNC is the Xerox of head porting: it doesn't begin with a scan of a stock head, but of a successfully manually ported head.
CNC does not design or improve anything, merely duplicates an existing contour.
Old 8th August 2021
Randy_rots Randy_rots is offline
Sportster/Buell Model: XL 1200 softail frame&NOS
Sportster/Buell Model #2: Buell XB1250 Uly XT
Randy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant future
Wow! Great work! I'm speechless...
Old 8th August 2021
Hippysmack's Avatar
Well it's was said before that somebody prints aluminum.
I guess it depends on having the right equipment.
I see those drawings the op made and all the potential I could do with that information.
All it takes is a will and way.
Accurate jigs for machining the op has already accomplished.
The list could be endless.
Old 8th August 2021
shanneba shanneba is online now
Here is an example of a 3D printed intake manifold for the Delta Wing race car.
https://www.racecar-engineering.com/...dge-of-racing/
2013 XL1200C
Find your Owner's Manual, Wiring Diagram and Parts Catalog here :
Enter your VIN OR
SportsterPedia.com
