Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Electrical and Ignition
0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Fifty150
0 Off Road Lights
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 HSR idle mixture screw
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
0 Front deflection
Last Post: denguy
Last Post: Fivecats
0 Ran out of gas.
Last Post: Hellbent_4
0 Best seat for long rides
Last Post: Diogenes415
0 need help with 68 XLH
Old 22nd August 2008
Ralph Shafer Ralph Shafer is offline
Sportster/Buell Model: S3T Thunderbolt
Ralph Shafer is an unknown quantity at this point
Unhappy 2001 S3T relay clicks, no crank
I left the the addtional headlights on and drained the battery the first day I rode the bike. After jump starting the bike to get to work the bike ran fine. I have a 120 mile round trip commute so I figured the battery would charge enough to stat again at lunch time. It did but it didn,t want to start again. The odometer and tail lights come on but the neutral light and the oil light only blink. I can hear the relay click but no check engine light. Since I had to jump start the bike and just to cover a possible I replaced the breaker and charged the battery. I also checked the diodes and tried a new relay in both positions. I don't see any obvious wire problems.
Old 23rd August 2008
Wink intermittant ignition problem-always check the switch
The problem was the ignition switch. I know that intermittant ignition problems are sometimes caused by a bad switch but I have a problem with trying to make things more complicated than they really are. When I calmed down and tried tuning the switch very slowly I found the sweet spot.
rottenralph's Avatar
I killed my battery once with the lights and ended up having to change it. These batteries are fickle. I bought a gel battery and I have been happy ever since. These batteries don't like to be drained that far.
Old 8th August 2014
Monte03's Avatar
Monte03 Monte03 is offline
Sportster/Buell Year: 1969
Other Motorcycle Year: 82
Adding to this Old Post, I had the same Issue, 'Clicking Only' a New Relay at and HD dealer cost 5.00, plugged it in, started right up, note- for 5.00 bucks I bought a spare..
Cycle World Oct 1962:
