Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Top End
Last Post: fafcpa
0 Indicators not flashing
0 Gear indicator missing
Last Post: mrmom9r
0 1975 Sportster
Last Post: IronHeadRon
0 Transmission drain plug
Last Post: mvent
Last Post: duffy
0 1982 rubber oil hoses
Last Post: Porkchop9
0 1975 Sportster
Last Post: Gulf Coaster
Last Post: Bikeaholic
Last Post: Animosity
Last Post: SophieWillow
Last Post: 84rzv500r
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: mikethebike61
Snuffy (72), cabby58 (63), SmoothyB (54), johnnyB (52), cayey (51), BIGschwerm (45), chief (45), Sporty Accorn (45), Muddypunk (36), Andreas (34)
Old 7th February 2007
cootertwo's Avatar
cootertwo cootertwo is offline
Sportster/Buell Model: 06 883/1200 Sportster XLC
Sportster/Buell Year: 06
Sportster/Buell Model #2: 1200 Roadster
Sportster/Buell Year #2: 2004
Other Motorcycle Model: Triumph Rocket lll
cootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to all
"vent relocation kit to remove the vents from the airbox and move it to a catch can or remote breather." Back to plan "B"
One Day At A Time
Old 30th May 2007
earl87gta earl87gta is offline
Sportster/Buell Model: X1 Red Race stripe
earl87gta is an unknown quantity at this point
I changed to the XB covers with PVC valves on my 2000 x1 I use to have to dump my catch can every time I got on the bike its been 2 years since I changed to the PVC valve set up and have yet to have to dump the catch can and thats with riding the dragan a few times a year. for you guys that are looking to save cash and go th the catch can I made my own vented cans for $15 each I use to run three on the buell one for each head and one for the trans. on a hot day I would have to dump them 2 or three times if I road the bike hard.
Old 5th June 2007
some pics from up top
Old 5th June 2007
you can go here to see more pics. http://home.earthlink.net/~328redracingstripe/id1.html
Old 5th June 2007
chrishajer's Avatar
Sportster/Buell Year: 1988
earl87gta: those are some nice pics, but your X1 breathing system is the same as the XLs. People were curious about the breather setup on the XB models. Have any pictures of that?
--Chris
Old 7th June 2007
that is an XB breather sytem those are rocker boxes off an XB. the origanal X1 heads had the ruber butterfly valve in side the valve covers. all I did was route them to the rear of my bike to K&N fillters instead of back in to the air box. I have pics of the origanal X1 covers if you want to see the diffrence. on the origanal pre XB there is a hose barbe off the side of the head that the butterly valve vented threw on the new XB covers all you get are those PVC valves. I went to them becuse I got tired of oil in my TB. on days when she was spitting a lot of oill It would start to back fire at around 80 Miles an hour. I dont have that problem any more. oil goes to a catch can and stays out of my TB.
Old 7th June 2007
frankyboy455 frankyboy455 is offline
Sportster/Buell Model: rowemachine sportster
Sportster/Buell Year: 1991
frankyboy455 has disabled reputation
If your catch cans almost never need emptying, can we conclude that the pcv system is efficient enough to let the hoses coming from the pcv breathe in the air cleaner and that there will be almost no "spitting" ? Anyone thought of plugging intake manifold vacuum directly to the pcv valves like on a car ?
Old 7th June 2007
chrishajer's Avatar
earl87gta: thanks for clarifying that. I saw the tube frame and didn't look closely at the breather setup.
Thanks,
Chris
Old 16th June 2007
No problem my bike is not a noraml Buell. I run them to small fillters to the rear of the bice under the seat. I would think its safe to say you could still run them to the air cleaner and not have to wrry about engine studder from getting fed oil in the air. you could always do what I did run a catch can for a while stock see how much oil you get then run it with the new covers and if your bike is nologer spitting oil ditch the cans. I made my catch cans coast was a hole $15 for three I put one on the trans and one on each cylinder. I can tell you this the front cylider is the one that spits the most oil dont know why but it does Ive had 2 buells and it was the same for both of them.
Old 30th August 2018
tattooglisha tattooglisha is offline
Sportster/Buell Model: xl1200s
Sportster/Buell Model #2: XL1200S
Sportster/Buell Year #2: 1998
tattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to all
More on breathers setups pls!
