Last Post: Fifty150
0 Off Road Lights
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 HSR idle mixture screw
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
0 Front deflection
Last Post: denguy
Last Post: Fivecats
0 Ran out of gas.
Last Post: Hellbent_4
0 Best seat for long rides
Last Post: Diogenes415
0 need help with 68 XLH
0 2021 Iron Butt Rally
forward controls
Old 8th April 2009
javelin javelin is offline
javelin is an unknown quantity at this point
Exclamation putting on forward controls and need some help
I'm trying to put custom chrome o-ring style part #49-0412 on my 1988 xlh. I've got a couple of problems. On the right side i took off the brake lever and old foot peg but how do I get the part they were attached to off. It looks sort of like a bullet with a hole in the end. And on the left side how do i get the stud that the foot peg and its bracket were bolted to off?
thanks
Old 8th April 2009
beuz's Avatar
beuz beuz is offline
Sportster/Buell Model: SPORTSTER "old boy"
Sportster/Buell Model #2: SPORTSTER CR (sold)
Sportster/Buell Year #2: 1998
Other Motorcycle Model: Suzuki GSF 650 Bandit
beuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond repute
On the right side, you'll have to remove the front sprocket.
To do it, remove your both mufflers and untighten the rear cylinder pipe.
That way you'll be able to remove the rear brake pedal clevis and rings.
Their's a big nut with a pin inside the cover.
You live more in 5 minutes flat out on a bike like this than most people do in a lifetime...
Burt Munro.
Old 12th April 2009
Thanks for the help. I finally finished putting them on.
Old 12th April 2009
ReddTigger's Avatar
You need to get to 5 posts so you can upload pictures, we're all waiting !
States I've Ridden in
71.3 hp 70.8 tq
Old 28th March 2016
Tizz440 Tizz440 is offline
Sportster/Buell Year: 1982
Tizz440 is an unknown quantity at this point
theres a clip you pop off
or i just did mine i had to take my exhaust off,my rear master and the sproket cover
theres a cotter pin and a nut on the inside,
i traded my mids for forward now i have no controls i need some frame brackets or something
