0 Gear indicator missing
Last Post: Shahyaan
0 Transmission drain plug
Last Post: mvent
0 Indicators not flashing
Last Post: IronHeadRon
0 1975 Sportster
Last Post: duffy
0 1982 rubber oil hoses
Last Post: Porkchop9
0 1975 Sportster
Last Post: Gulf Coaster
Last Post: Bikeaholic
Last Post: Animosity
Last Post: SophieWillow
Last Post: 84rzv500r
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: mikethebike61
Johnc (75), x750rider (68), bart53 (68), bad rad (67), halfdrive (56), jag1 (49), Zuhaib (37)
883, tires, wheels
Old 6th March 2010
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
You can run up to a 110 on the stock rim.
You need at least a 3" rim to run a 120. It will fit though, without a fender.
On the back a 16x150 tire will fit under the fender, and on the stock rim. Some brands of 160 might even fit, but they're going to be really close to the fender.
Old 7th March 2010
Madmax42's Avatar
Madmax42 Madmax42 is offline
Sportster/Buell Model: xlh 883 Hugger
Madmax42 is a jewel in the roughMadmax42 is a jewel in the roughMadmax42 is a jewel in the roughMadmax42 is a jewel in the roughMadmax42 is a jewel in the roughMadmax42 is a jewel in the roughMadmax42 is a jewel in the roughMadmax42 is a jewel in the roughMadmax42 is a jewel in the roughMadmax42 is a jewel in the roughMadmax42 is a jewel in the rough
Had a question and you guys never cease to amaze me. Do a search and you will be sure to answer almost any question you might have about the sportster here.
Madmax42
Old 28th March 2015
Lucky13Kustoms Lucky13Kustoms is offline
Lucky13Kustoms is an unknown quantity at this point
Madmax42
Damon straight
Old 28th March 2015
Auto-correct, keeping me clean again
Old 1st June 2015
Kayakeur's Avatar
Kayakeur Kayakeur is offline
Sportster/Buell Model: XL883C
Kayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of lightKayakeur is a glorious beacon of light
Default D401, MH90-21-54H: can I go wider?
How wide a tire can I put on the front of my XL883C, 2005?
Without changing rim because I assume a new rim would be costly.
Laced 21" rim is 3 inches wide O.D., Outside width using measuring tape, not caliper.
Current tire original HD Dunlop D402F, MH90-21 -54H: tire width 86mm with measuring tape (not caliper)
Distance fork to fork is 5" (127mm).
Installing new Commander II's front and back.
Looking to widen to get bit more stability, stickiness. Or will upsizing degrade behavior (I mean bike behavior not mine).
Thanksssssssssssss
Budster Kayakeur June 2, 2015
