0 08 Nightster No Start
Last Post: jammantoo
0 2 into 1 exhaust build
Last Post: ericfreeman
Last Post: LLOYD883
Last Post: SportyHD
5 Do you feel you pay too much for Motorcycle Insurance?
Last Post: Eric Von Zipper
0 compression problems
0 900 dual carb front head
Last Post: Eddie Lives On
0 wanted rim info
Last Post: curiousgeorge
Last Post: RAIDER0372
0 Air Filter Soaks With Gas
Last Post: Hopalong48
0 A Day in the Life...
0 Should I buy a Sportster??
Last Post: geekonabike
0 Project Strociek
Last Post: Animal611
Last Post: VaFish
  #31
Old 5 Hours Ago
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
Project stalled just at the moment. I have now broken TWO 1/2" impaxt inhex sockets trying to remove the front rotors from the 79 !
Yes, I know they are installed with Loctite (red probably ?) and I tried foing it both by hand and with a rattle gun.
I dunno. Maybe not enough heat ? I though 400 degrees would kill it. Don't really know how hot I got them used a propane torch.
I know these aren't left hand thread. I tapped them left and right to start with. Tapped the bolt before I began.
Only thing I didn't do was penetrating oil overnight.
I'm about to give up and send it to a machine shop.
Anyone else have this much trouble with disc brake bolts ?
(I'm beginning to like drum brakes)
