0 EFI hose clamps
Last Post: Bikeaholic
0 Removing oil pump
0 Grounded
0 Quick Question
0 Front end swap
Last Post: kiwicafesporty
0 American Cycle Fab???
Last Post: THEWILDONE
0 Hardtail sporty ideas
0 Trade: 91-03 Forward Controls for Mid Controls
Last Post: Kennyv
0 Brake Line Part Number ?
0 Massachusetts rides 2019
0 Hot
5 Keeping Secrets?
Last Post: flashedwards
4 The no-debate OIL POLL
0 Robbie's uncomfortable seat theory
Last Post: dieselvette
0 Tuesday 23rd July 2019: Lympstone
0 turn key on, no power at battery. key off battery good. help
Last Post: ken883/1200
0 Torquing Rubber
Last Post: bimbo
0 How many (Sportsters Do You Own?)
Last Post: screndname
Last Post: Tincan
0 Single women, how old are you?
  #91
Originally Posted by Cmd11 View Post
They both have there pos and cons I have no issue with the stock one.
They're not terrible carbs but they are limited in tuning parts. It's hard to get the off idle transition right. Most just hide it by adjusting the idle overly rich.
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: 1200Lr
Sportster/Buell Year #2: 2016
At higher elevations your motor is starving for air. Having the slide lift less doesn't make that better. If you're actually riding at high altitude you jet down CV carbs just like non-CV carbs. Manufacturers considered hi-altitude as being 4,000+ ft.
Despite your experience you seem to be missing a key part of the equation. Specifically how the fuel is metered by the main jet and needle.
Yes, if a CV carb is to be exclusively used at altitude you would make a change, most likely to the pilot jet and screw as the idle circuit is not effected by the main needle and vacuum diaphragm.
But the main jet and needle will meter less fuel to better match the reduced air mass/oxygen.
Again the Mikuni does not, it will deliver the same amount of fuel resulting in a much richer mixture at altitude since the needle will pull further out of the main jet than the CV in the same circumstances.
dieselvette's Avatar
dieselvette dieselvette is offline
Sportster/Buell Model: Roadster-Glide
dieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to beholddieselvette is a splendid one to behold
I haven't tried to keep track of who's in which pissing match, and I kinda wish that a few posts in this thread could be deleted that aren't related to carbs or EFI at all.
We're really splitting hairs here. You can look at NRHS or Hammer and see the dyno tests proving the Mikuni can make more HP, but without a doubt for cross-country riding from sea level to milehigh+ altitude and temperatures ranging 40 to 100 degrees and rain then desert, the CV carb will get you there faster (because you don't have to stop for adjustments) on less gas.
No matter what carb, if you want perfect A/F ratio 100% of the time you would have to adjust for conditions but with the CV you will do it less. So is it fair to say the HSR is better for performance, but the CV is preferred for normal every day riding?
"Life is never made unbearable by circumstances but only by lack of meaning and purpose" - Viktor Frankle
FIND HELP WITH YOUR SPORTSTER HERE: http://sportsterpedia.com/doku.php
2004 1200 Roadster Custom-Electra-Glide-Sport-Touring-Edition
SE air cleaner w/venting routed outside a/c
Supertrapp 2:1 pipe - usually 20 discs w/closed endcap
Stock CV carb w/ Yost tube + DS idle mixture screw
Cycle Electric 38A charging system
Corbin 2-up seat (plus AirHawk for LDR)
Metzler 880 front & rear (usually)
QD windshield - sometimes with SlipStreamer glass + driving lights
Custom hwy pegs - sometimes with lowers mounted
Trailer hitch, when needed
Currently working on improving MPG:
TC88A ignition
Valve job & rings - 0.030 squish, bump up compression?
Bronze oil pump gear
Update oil pump to '07-up
30-tooth HDI belt sprocket (137-tooth belt)
I've run both and I'd rather have the HSR for normal everyday riding. But I like my bikes to run well and don't do my jetting (or mapping) by internet polling...
Have fun. I'm done as this is clearly pointless.
DRAGONLORD69 DRAGONLORD69 is offline
Sportster/Buell Model: XL1200CUSTOM
DRAGONLORD69 is an unknown quantity at this point
I specifically looked for a 1200C and it had to be carbed. This 05 showed up literally a mile from me 3 years ago.
yep I preferred the carbs I got one of the last carbed 1200C in black too
no wobbles i had it for 8years it was a 2006 and had just 10 thousand was just starting to smooth out when i got it
I got a great deal on it as the previous owner hardly rode it and had fallen off it at the lights at a standstill
on it when I got it its never been any trouble except for it spitting the clutch spacer rivets a couple of years back and then the throw out bearing last week i have done over 20 thousand miles on it since I had it
