Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle Engine Conversions
0 A Day in the Life...
0 first harley- help!!
Last Post: rickthrash99
0 Hope Cove, 20th May 2018
Last Post: ReddTigger
0 Ebay Guantlet Fairings or Burly Outlaw Fairing
Last Post: wongjohnson
0 Future of the sporty?
0 Clutch cable options
Last Post: Darkseacret
14 This is how they Roll in Germany
Last Post: seajay
0 Intro from New England
0 Spring Seat Brackets?
Last Post: tylerd.green
Last Post: Moon Wolf
0 Feeling in trouble.
0 WTB: Black 3.1gal tank for '82-'03 Sporty
Last Post: Pender1
0 HAMMERPerf 90" In the Works
Last Post: MatHormell
Last Post: webman94
Last Post: mac93
Last Post: Ben221
Last Post: The Crusher
Last Post: kmul
Last Post: Roosterman
Last Post: Jowniofownio
0 Engine dies when choke off
dtw757 (64), XLH75Rider (63), JRLang13 (56), Shaerona (54), christophe (51), collectovince (50), buckethead (40), Hang_Em_High (38)
90ci, big bore, engine builder, hammer performance, patriot defender
  #1431
Old 4 Days Ago
MatHormell's Avatar
Sportster/Buell Model: XL883R
Originally Posted by jkinkade View Post
Hi Mat sorry for hijacking your thread!
hey thanks for the steering damper link.
interesting about ccp,i have seen it go up just changing the primary ratio to a lower gearing & also on a Harley race bike with no starter, we used two different starter's, one could spin the motor faster. when we used the remote starter that turned the motor over at a faster speed & tested ccp we got higher ccp.
ya, I think its due to a few variables, IE the micro blue and skirt coating helping with rings seal and the reduced friction + the high cranking amp lithium ion battery spins it over much better than the previous battery. Combined I believe is the result of the higher cranking compression. I'm going to continue to do runs around my home area on 93 octane and see how it goes. Thing is an animal on the street, tire has zero hook up when laying on the throttle, but hasnt tried to lift the front tire at all yet.
Got the steering stabilizer stuff worked out now I believe. Still need to finish mounting it but got it in a way everything clears and turns. Might be able to get it to the track next weekend if all works out well.
[SIZE="1"]
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
Axtel Cast Iron Cylinders
HAMMER PERFORMANCE .600 Cams
1.725 Ratio S&S Rocker Arms
HSR 48 Miunki
Conical Valve Springs
S&S Premium Lifters
Dynatek 2000i
WorldWideBearings
Patriot Defender Exhaust
[SIGPIC][/SIGPIC][/SIZE]
Old 3 Days Ago
jkinkade jkinkade is offline
Sportster/Buell Model: XLH 1200 2003
jkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to behold
Sounds like all the trouble you went to with coatings was well worth it!!
I would play with rear shock settings to see how that effects hook up to. is you gear ratio lower than stock?
get a Shinko Hook up tire!
2003 XL1200
Old 3 Days Ago
MatHormell's Avatar
Yes a shinko is for sure on the to do list, might get the street tire version of the hook up, it's only slightly less sticky and last a tad bit longer.. It was the tire everyone used before they came out with the hook up, tread looks damn near the same
So I was able to make my short shindy stabilizer work, just had to get all the mounting locations in the perfect positions to allow for full travel in each direction..
Still wasn't satisfied with the stiffness the a shindy provides so I rebuilt the stabilizer using a mix of tungsten disfulfide and heavy weight fork oil. Got it all rebuilt and is much stiffer now in the lower positions and probably twice as stiff as before in its highest stif setting. Going to mount it back on tonight and take her for a high speed run to see how it's stability feels on the big end..
Old 2 Days Ago
cycowrencher's Avatar
cycowrencher cycowrencher is online now
Matt,
The v3 stealth will give you about 2000 to 2500 street miles. Half that racing. The hookup maybe 400. Mount the widest v3 you can.. I had traction issues with the 170.
Old 1 Day Ago
MatHormell's Avatar
Originally Posted by cycowrencher View Post
Matt,
I ran run either 180 or 190, 17" wheels.. Have unlimited tire options to choose from
Old 1 Day Ago
Go with the 200 or 210 if you can fit it. You have 50+ hp on me and the 170 was just enough.
Old 3 Hours Ago
MatHormell's Avatar
Probably could, its a 7" rear wheel
