2 Weeks Ago
Momentary Specialist
Posts: 709 Sportster/Buell Model: XL1200 Sportster/Buell Year: 1996 Other Motorcycle Model: ST1100 Other Motorcycle Year: 1999
Originally Posted by princealbert
Still curious ..... if these are a direct replacement (ive bought front left caliper) , why didnt the OP reuse the Harley bolts from the stock mounting ?
Also, they come packaged with a chrome (spacer?) of some sort. Anyone know what its for and where to mount ?
I used this caliper for the left front, no spacer.
The original caliper is a floating caliper. The bolts and threads are completely different than what the Wildwood uses.
The Wildwood bolts on solid with 3/8-16 thread bolts.
The spacer might be for mid glide application?
Sleepy Labeef rides again!
2 Weeks Ago
Looks like a RH caliper
2 Weeks Ago
Posts: 6,126 Sportster/Buell Model: XL77.2R Sportster/Buell Year: 2006
Originally Posted by farmall
I anti-seize or Loctite nearly every thread no matter the material since both exclude moisture. I've taken apart hardware I installed thirty years ago on bikes, trucks etc with zero problems. Electrical parts like starter cable studs get dielectric silicone grease.
Marine anti-seize with copper or high temp anti-seize with nickel are more expensive but a container lasts years.
Copper anti-seize is incompatible with Austenitic Stainless Steel.
2 Weeks Ago
Posts: 12 Sportster/Buell Model: Sportster 883 Hugger Sportster/Buell Year: 2002
not MY caliper ... just grabbed a pic to show how they come ... and what the spacer thing looks like.
Thanks for the info on bolts ie different length required.
This is a quote from another forum, someone who has had positive results from this upgrade.
They do in fact bolt right on...once you get the correct bolts, which Wilwood does not include. What you need are two 3/8" x 16TPI x 1" bolts (per caliper)
1" bolt "sounds" short .... can anyone confirm this bolt info? and I`ll get hold of some pronto.
2 Weeks Ago
Posts: 249 Sportster/Buell Model: XLH Sportster/Buell Year: 73
Beats me. I would email Wilwood tech support and ask. I suspect it's to make one part number have offset options to fit two different rotor offsets, perhaps for narrow and wide glides.
2 Weeks Ago
1” sounds about right, but I don’t remember for sure. The bolts are short, as there is not many threads in the caliper, and the caliper is close to the rotor. The bolts are only tightened to 20 lb-ft!
I used two different length bolts. A shorter one in the bottom hole... if it’s too long it can contact the rotor, especially if you are using floating style rotor.
I installed a longer bolt in the top hole. With the threads sticking through the caliper just enough to fully engage a self locking nut. (As a back up nut) I salvaged a used caliper and didn’t fully trust the threads. I also applied loctite to the bolts.
See how close the bottom bolt is to the rotor bobbin in this photo
My bikes down in the barn and covered. I can double check bolt lengths tomorrow if you need it.
2 Weeks Ago
Thanks for all your help.
Oh guess what ? they sent me a Right hand caliper
invoiced for a Left and sent a Right.
So I cant even throw it on for a test fitment, but yeah, the 1" bolts are starting to look right, just sounded short to reach through the fork lugs and the caliper mount.
We`ll get there in the end.
2 Weeks Ago
Posts: 3,304 Sportster/Buell Model: XLH 883 Sportster/Buell Year: 1991
I'm looking forward to an exact list of what bolts are needed for install. Might buy myself a Wilwood caliper for Xmas!
John
2 Weeks Ago
John
Exact List:
Qty 2) 3/8” X 16 bolts, 1” long.
Qty 2) 3/8” flat washers (thin)
I’d recommend at least a grade 5 bolt.
2 Weeks Ago
Originally Posted by Maxeffort
Exact List:
Thank you!
John
