10 dragpips to muffler pipes
Last Post: smilinbrad
Last Post: Yakcm2
0 Getting Hammered
Last Post: Bryan83taco
0 Which Battery?
0 Leineweber camshaft
Last Post: slojoe631
0 question for our machinists
0 WTB drag pipes for 2001 sporty
Last Post: Kejobe
0 Wire Tuck with No Tank Lift and No Rewire
Last Post: TheBreeze
0 A Day in the Life...
0 piston rings
Last Post: Nitro57xl
0 more stumble on cold start
Last Post: smm1200
0 Powerraythor conversion
Last Post: saddlebagrail
0 Fat Ironhead?
0 2015 sportster charging
Last Post: Jaime1840
0 3.5" straight riser
7 Ironhead yes or no
0 Front Cylinder Gasket Leaks
0 *DK Custom - Our Gift to You - Holiday Savings*
0 1999 Sportster 883XLH
Last Post: Guppy916
0 Electrical question
mdgtmstng (66), robc (54), 09 sporty (51), bimmer10 (49), DougZ (46), mtntrout, JTedd9 (44), blueoval78 (41), Everett (39)
NLXL's Avatar
NLXL NLXL is offline
My '92 model has '883' stamped on the cylinder base, right side, just behind a pushrod, hard to see. There's also some kind of 'A' sign and ''91' stamped on the same side.
Patagonia to Alaska
https://www.itchyboots.com/
Highly-Dangerous's Avatar
SPANIARD
Sportster/Buell Model: XL 883
Be careful to choose the right one - They have them in 883 and 1200 versions - and aftermarket, they have them in 1250 and 1275 versions...
The main part measures across the cylinder diameter and the wire portion on the bottom will measure the depth of the stroke...
OP --- Welcome to the XLForum ! !
LMAO!!!
rejeanprimeau's Avatar
That a barrette.
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
I find those laying around the house everywhere. She must have a 100 of them. Who would've thought I should put a few in my tool box.
hammer6315 hammer6315 is online now
Twist the grip! If it pulls hard to upper rpms, its a 1200. If it falls flat and stops accelerating half way up, its a 883.
