0 Not shifting out of 1st gear or Neutral
Last Post: webman94
Last Post: jharback
0 cancer
0 Metal Polishing
Last Post: ed_in_az
0 Rigid Mount Fork Info
0 Royal Enfield 650 Twin: $5799, 47HP, ABS
Last Post: farmall
0 Moto Guzzi V9 Bobber debut
Last Post: farmall
Last Post: Magneto Sportster
0 When Were You Born?
Last Post: MacSporty02
0 BMW R 1200 GS clutch replacement
Last Post: farmall
0 Mid controls on a Custom
Last Post: SportstrKurt
Last Post: Curvemadd3
0 This Mikuni vm38-9 is driving me insane
Last Post: DirtyHarry68
0 Cam cover
Last Post: Pezed
0 easy seat fix for 2004-2006 1200c
Last Post: chain
0 Installing Brembo Goldline brakes on a 1998 XLH1200
Last Post: Randy_rots
3 Ironhead Pictures Thread
Last Post: Pezed
0 Anybody Collect Dealer Logo'd Harley T-Shirts?
Last Post: BWP 5p
0 Led upgrade 1200S
Last Post: NZstu
0 seat bolt
0 where is that air shock thread?
Last Post: robbie202
0 Lithium battery earthx
Last Post: Tucsonmax1
View Poll Results: Is your Jiffy Stand Stock, Modified, or Replaced?
Stock (factory) 15 62.50%
Modified (bolt on extention or welded on) 5 20.83%
Replaced with aftermarket or different factory Stand 4 16.67%
Replaced with a self fabricated Stand 0 0%
Voters: 24. You may not vote on this poll
jiffy stand
Subscribing Biker
Question Jiffy Standing
Do you have the stock jiffy stand or have you modified it or replaced it with a longer/shorter one?
A long time ago,I found that if I had a passenger or luggage/pack on my pillion pad, I couldn't get my heel under the primary to put my kickstand down. On a few road trips, I had to get one of my friends to come over and put it down for me, until I got the bike unloaded.
I tried a few different extensions and finally used a "barefoot" (goes over the headlight dimmer button on the floorboards) that I had a'73 Nova I had bought new. Ground flat the the dimmer switch retainer, drill 2 holes in it, and threaded 2 holes int the Jiffy Stand. Has worked great since.
Wyo George Wyo George is offline
Wyo George is a name known to allWyo George is a name known to allWyo George is a name known to allWyo George is a name known to allWyo George is a name known to allWyo George is a name known to allWyo George is a name known to allWyo George is a name known to allWyo George is a name known to allWyo George is a name known to allWyo George is a name known to all
I have a longer one because I raised my bike about 3.5 inches.
Folkie Folkie is offline
I bolted on the # 50462-11 extension. That's on my '15 CB.
On my '13 '72' and '05 Custom (same thing, really) I had the # 50250-04 extension.
man mr. toe, that brings back memories.
unfortunately i go further back to the stomp starter switches.
lucifer_mr2 lucifer_mr2 is offline
Sportster/Buell Year: 2012
lucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant future
Put on a longer one, when I did my suspension, even with that it still leans a bit much.
Old 4 Days Ago
WI_duker's Avatar
WI_duker WI_duker is offline
Sportster/Buell Year: 1988
Other Motorcycle Model: Blast
WI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond repute
Its hard extending my jiffy stand.
Sometimes I have to pull it down by hand. Not very safe
It's Hammer time
