0 Spokes or Mags
5 1969 XLCH exhaust question
0 93 Sporty Key replacement
0 Clutch Squeal
0 Mid or forward controls.
Last Post: FiftySixer
0 Simplified Wiring and Bars
Last Post: Oldmxdog61u
0 Starter Help - Need Help Diagnosing
Last Post: cazz1000
0 4 Speed Stator Replace
0 Rear Rocker Gasket Blown
Last Post: MartinSlater
0 compression low?
Last Post: Hornsmith
Last Post: Joe_jeep
0 Power cones
Last Post: davixlrtt
0 Pics of your significant other
0 Huge pile of Ironhead Parts
0 Should I buy a Sportster??
0 '04+ Starting Issues, Do You Have Them? - Poll
0 Poll: What weight fork oil do you use?
Last Post: Medyo Bastos
0 Generator removal
Old 25th March 2020
Piccollob12 Piccollob12 is offline
Sportster/Buell Year: 1970
Piccollob12 is an unknown quantity at this point
Default Primary oil amount with taller front end.
I am curious if i should still follow the rule of fill up till it drips on my 71 ironhead
I have a 21 inch front wheel and extended tubes. I’m wondering if the stock 28 oz is enough since the oil puddles further back in the primary. I can def fit way more oil in there since the front is lifted up.
Curious on your thoughts!
-Justin - 1972 XLCH & 1983 FXR
Old 25th March 2020
Just put 28oz of oil in it and run it.
A 71 has a transfer valve and that will determine the "working" oil level.
Old 26th March 2020
Awesome!! Thanks for that!
