Last Post: jeffro57
0 Indicators not flashing
Last Post: steve-o-
0 1975 Sportster
Last Post: bplinson
0 1975 Sportster
Last Post: bplinson
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: lehel
Last Post: jibber
Last Post: Gulf Coaster
0 Gear and brake linkage
Last Post: 93trident
0 1965 XLRTT article
0 Starter Relay?
Last Post: Akdawg
Last Post: mac93
0 Q cams in 73 xlh ??
Last Post: 73HEAD
atengnr atengnr is offline
Sportster/Buell Model: sportster 883
Sportster/Buell Year: 89
atengnr is an unknown quantity at this point
Default 1985 Ironhead, help with dynatek 2000 install
Hello all, Im new to ironheads, and bought this not running, and had points conversion. I opted to install a dynatek 2000, but cannot get the status light to illuminate as I rotate it (other than when it is first turned on). Engine is at TDC (scribe line in sight window). Since I had to purchase a timing cup for this, I am wondering if I have the wrong one (jp cycles 383-497)?? The cup seems to be in the groove correctly. Any input appreciated.
Thanks
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Perhaps your on the wrong stroke. Roll it through and bring the mark around. Check for front compression..
Sportster/Buell Year: 1974
You have the correct timing cup. Also, you're using the right flywheel mark. On an '85, front cylinder TDC is a straight vertical line if your crankshaft is original.
Ok thanks. Then it seems I must be at tdc exhaust stroke. Dumb me.
