0 WTF Happened
Last Post: Bryan83taco
0 2020 Sportsters
0 Just bought my 48 and love it! However... (Expected Much More Power)
0 Flame's New 1989
0 Mikuni HS40 flatslide
0 super b overflow
Last Post: rickmodee
0 Hello
0 My 1250 to 1275 build
0 Ironhead questions
2 Humble pie
Last Post: Sprtstr1200s
0 Yet another issue with this build
Last Post: Bruce
0 Touring on A Sportster
0 Roseville CA?
Last Post: Bryan1976
Last Post: Moon Wolf
0 Ftr 1200
Last Post: Jason's Sporty
0 Valve to piston contact
0 Horn and starter button stop working
Last Post: Roane
0 Iron 883 headlight grill keeps spinning
Last Post: jjcsr74
Old 5 Days Ago
Rollbar's Avatar
Rollbar Rollbar is offline
Sportster/Buell Year: 1990
Rollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to behold
Default 90XLH Hugger Forward Control Help/Install Questions.
‘90 XLH Hugger.
I bought a set of forward controls and the two bolts running through the case seem to be a problem for me, at least at the moment.
1. Will the front motor mount and side motor mount hold the motor up while I remove the side (both) brackets?
2. Do I have to remove the oil lines?
4. If I remove the oil lines from the bottom (unscrew) will I lose my oil if the bike is on the kickstand (thinking most will be on the other side of the case//but I don’t know).
Thanks again, just don’t want to get into a mess and not be able to correct it.
Here is the top nut for the case bolt.
Here is the bottom case bolt nut.
Old 5 Days Ago
Rollbar's Avatar
I got it. I can see now the nut end is actually on the bracket.
Just couldn’t see it before.
Thanks
Old 4 Days Ago
Rollbar's Avatar
Got them installed.
