0 photo size
0 V&H slip on twin slash
Last Post: Jack250
0 TC88a DIY Power adapter ?
0 Fuel tank urns
2 Your daily tunes...
0 61xlh started with starter fluid
Last Post: Larry May
0 Still having trouble starting the 61xlh
0 Krome Werks HP Plus slipons - Replacements ?
0 2011 Harley 883 Iron 1250 Hammer
0 Figure Machine external breather
0 Black Bike Bible
0 Frankenbrakes
0 su carb question
Last Post: nychopper
0 Hello from Northern Alberta
0 Who Runs Turn Signals?
Last Post: Gpa
0 Stock Shocks/Oil Pump
Last Post: whetrick1
0 Too HOT to ride?
Last Post: Skeezix
2 My 1275 Hammer Conversion..
0 Trans corner fix
0 cam lobes
0 Misc. Parts/cleaning house
0 05 Sportster Manuals, Service & Parts
0 HSR42 Dealer Jet Kit
0 Daytona Twintec TC88/TC88A USB Interface
0 New Buell Rider From Southern MN
Last Post: Veeflys
hubbinator (71), sport53 (67), kship (55), jrmkel (41), IR88n3 (36), waltweezy45 (33), lumberjack (30)
Folkie Folkie is online now
Originally Posted by stikflote View Post
no good putting stock valves ,with a bigger camshaft
That depends on the cams. Ie: which cams, how high the lift, event timing, …
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
npaisnel npaisnel is offline
Sportster/Buell Year #2: 1993
npaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant future
Hammer Performance say
New plugs to use
10R12X
Harley P/n 27794-08
Replacing the originally recommended 6R12’s
Cooler plugs as Per Hammer Performance recommendation
rocketmangb's Avatar
Hammer also runs Denso and NGK
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Have you seen this video from Hammer
In particular scroll to 4 mins 50 seconds
https://youtu.be/F9d-AJ3R6Js
He talks about ‘’Hogging out ‘ the head to bring the compression ratio down with a flat top piston.
Hammer do not like that method as you loose the squish band.
That looks very much like what Alex at FastlaneHeadworks has done to mine ☹️, along with a flat top piston. I did not know, he did not mention the difference, we did not discuss.
My heads were taken out to 57 cc from the standard 49.
He recommended and fitted N4 cams, we discussed cams and I did say I preferred power lower down. The N4 cams lifts the power up a bit. If what I have now been reading is correct, I should have gone with W grind cams. ��.
Alex turned my bike around in 8 days or so. I had to come up from Jersey which took a bit of organising with his other work. FastLaneHeadWorks is Alex working from his well equipped workshop attached to his home. A constant stream of bikes from what I saw, he does good work, and is well recommended not eh Facebook Sportster Sickness group. Not sure where he gets the Dyno work done. He does all the machining himself.
Alex got my bike done in a tight schedule, and it all worked out well, but it could easily have gone wrong. I only had two weeks in the UK, and Alex’s other ‘day job’ is oil rig related, where he has to shoot off at a moments notice to fix whatever oil rig related machine that has failed. So it was always possible that I could have been left with the bike not done in time, it was the risk I knowingly took to save sending my heads off to the USA If you have a schedule to work to it could prove challenging.
If I had seen those Hammer Performance videos and asked about cams here, before I spoke to Alex, J could have asked him to use the reverse dome pistons and W cams.
But if I was doing it again, I’d send my heads to Hammer for their Sledge or Crush head jobs.
Live and learn, what with my costs of coming to UK for two weeks I could have got more HP for my money. Ended up costing me as much as the Hammer ‘120HP plus ‘ kit ( with my travel etc) to get 84 HP, plus it now looks like I have ‘hogged out’ heads I can’t do anything else with ����
Alex is a very nice chap, very helpful, maybe he is not aware of the reverse dome piston option. Worth discussing with him.
I have asked that question in another thread..http://xlforum.net/forums/showthread...57#post5801757
60Gunner's Avatar
Chief of Security
You could've done Hammer's 570 cams too and had both the power down low like the Ws AND the power further up like the N4s at the same. time.
The trouble with trusting others..
The well too late now.
