0 Figure Machine external breather
Last Post: Bryan83taco
0 Trans corner fix
0 Stock Shocks/Oil Pump
0 photo size
Last Post: fafcpa
0 V&H slip on twin slash
Last Post: Jack250
0 TC88a DIY Power adapter ?
0 Fuel tank urns
2 Your daily tunes...
0 61xlh started with starter fluid
Last Post: Larry May
0 Still having trouble starting the 61xlh
0 Krome Werks HP Plus slipons - Replacements ?
0 2011 Harley 883 Iron 1250 Hammer
0 Black Bike Bible
0 Frankenbrakes
0 su carb question
Last Post: nychopper
0 Hello from Northern Alberta
0 Who Runs Turn Signals?
Last Post: Gpa
0 Too HOT to ride?
Last Post: Skeezix
2 My 1275 Hammer Conversion..
0 cam lobes
0 Misc. Parts/cleaning house
0 05 Sportster Manuals, Service & Parts
0 HSR42 Dealer Jet Kit
0 Daytona Twintec TC88/TC88A USB Interface
0 New Buell Rider From Southern MN
Last Post: Veeflys
hubbinator (71), sport53 (67), kship (55), jrmkel (41), IR88n3 (36), waltweezy45 (33), lumberjack (30)
View Poll Results: What synthetic oil brand do you use in your cars or your bike. You choose more than 1
Amsoil 342 24.43%
Mobil1 539 38.50%
HD SYN3 291 20.79%
Royal purple 59 4.21%
Shell 16 1.14%
Castrol 83 5.93%
Penziol 13 0.93%
Other 217 15.50%
Multiple Choice Poll. Voters: 1400. You may not vote on this poll
  #461
Old 4 Days Ago
Highly-Dangerous's Avatar
Highly-Dangerous Highly-Dangerous is online now
SPANIARD
Sportster/Buell Model: XL 883/1275
MOTUL 7100 20W50
Old 4 Days Ago
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Originally Posted by Highly-Dangerous View Post
MOTUL 7100 20W50
Are you running this in your motor? Pretty pricey MC oil. I can do an oil change for the cost of 1 qt of that.
That ma2 rating doesn't mean jack in a Harley motor that doesn't share a sump.
Run it in the primary maybe depending on the clutch you're running and whether or not the synthetic will cause slipping.
Old 4 Days Ago
burely burely is offline
Sportster/Buell Model: 03 883 custom
Sportster/Buell Year: 03
Other Motorcycle Model: 1999 BMWK1200LT
burely is an unknown quantity at this point
Originally Posted by Bikeaholic View Post
Evo Sportsters do not share Engine and Transmission oils.
correct i was wrong the primary/clutch and transmission does
2003 883 custom anniversary black 1999 BMW K1200LT Aprillia sr50 70cc
Old 4 Days Ago
glbsportster's Avatar
glbsportster glbsportster is offline
Sportster/Buell Model: 1200 C
glbsportster has much to be proud ofglbsportster has much to be proud ofglbsportster has much to be proud ofglbsportster has much to be proud ofglbsportster has much to be proud ofglbsportster has much to be proud ofglbsportster has much to be proud ofglbsportster has much to be proud ofglbsportster has much to be proud ofglbsportster has much to be proud ofglbsportster has much to be proud of
There is a difference between viscosity (a measured value) and viscosity grade (which spans a range of measured viscosity values). The measured viscosity of a particular oil changes constantly with temperature. The viscosity grade of an oil (e.g. 10W-30) does not change unless the oil is actually damaged.
There are three parts to the SAE viscosity grade. The last number (20, 30, 40, etc.) defines the “major” grade. It is determined by the oil’s measured viscosity at 212°F (100°C) and is the most important part of the viscosity grade. It should be considered the operating, or effective viscosity grade of the oil. The “W” stands for “winter”, and not “weight” as is commonly believed; and the first number combined with the W is the “winter grade”. The winter grade of a multi-viscosity oil is determined by two parameters: the Cold Cranking Viscosity; and the Pumping Viscosity. These viscosities are defined as maximum viscosity values at various sub-zero temperatures. All of this is defined by SAE J300. To me it would seem totally advantageous to use 15w-60 oil, since even Harley recommends a straight 60 weight at certain ambient temperatures. The best way I have found to reduce the so called "noisy engine" is to remove my hearing aids and put on a helmet. Joking aside, my engine to me does not seem to be as noisy as cycles I rode back in the 50s and 60s. The concern of normal engine noise does not really concern me.
Old 4 Days Ago
Just some additional info on viscosity and so on.....one of the interesting points is if you are at the maximum point of the range for 50 weight oil it could be at the minimum point of the range for 60 weight. If I recall correctly and since I have been looking at many numbers lately....I could be wrong....but I think Mobil 1 Twin oil for Harleys the 50 weight topped at 20.6 ( I will check later and correct if wrong) but, if so it is very close to being a 60 weight. Anyway, thought some of you might like to check this out, if not scroll on and enjoy your day.
Old 4 Days Ago
SPANIARD
Been running this on my S&S BT for years (also in the primary with no issues)... I was going to run it on the Sportster too.... BUT... after reading all your posts about the Valvoline VR1 and doing some "homework" I´ve decided I will run the VR1 in the Sportster... (Spectro in the primary/trans).
Hopefully I will have the conversion finished this evening or tomorrow morning... working against the clock at the moment as on Friday I must catch a plane, again!
Old 4 Days Ago
harley506d's Avatar
Sportster/Buell Model: 1200c
Nothing wrong with the Motul.
Makes more sense if price is a factor.
https://www.ebay.fr/itm/Huile-MOTUL-...MAAOSwz9la21DF
https://www.amazon.fr/Valvoline-Raci...2132728&sr=8-2
Old 4 Days Ago
SPANIARD
Originally Posted by harley506d View Post
Motul is very good oil!!
Slightly cheaper here in Spain...
https://www.amazon.es/MOTUL-7100-20W...gateway&sr=8-1
Valvoline... good price in this page:
https://www.todoparatucoche.com/lubr...941023021.html
