0 HSR42 on a 90" ?
Last Post: Merch131ho
Last Post: Four Speed
Last Post: ChrisOfTheOT
0 Mikuni HS40 flatslide
0 Ironhead questions
0 Flame's New 1989
0 WTF Happened
Last Post: Vohnsen
Last Post: Johnmotoguy
Last Post: jharback
0 started her in gear
0 super b overflow
0 Falling out of 1st
Last Post: joes95bobber
0 My 1250 to 1275 build
Last Post: Scott
2 Humble pie
Last Post: Sprtstr1200s
0 Operation Live Wire
Last Post: WI_duker
0 2020 Sportsters
Old 4 Days Ago
Rollbar's Avatar
Rollbar Rollbar is offline
Sportster/Buell Year: 1990
Rollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to beholdRollbar is a splendid one to behold
Default What Years Actually Fit the 1990 XLH?
If there is a link then I must have missed it. Sorry bout that.
-Continually I see that parts are suggested/listed for 1986-2003 only to find it not the case etc, for my model year ('90).
-So, what actual model year will work on a '90 for parts etc.
-Will '91 parts; '95; '2000?
-As you know the parts seem to be getting slim and I was just wondering if the later model years would work?
-Hopefully this will open up the search field.
Thanks,
Old 4 Days Ago
All parts have their range of compatibility - not all the same...
Each year, the MoCo replaced some parts with newer versions... So you have to ferret out which years fit what based on when it was first implemented & when it was later replaced with another upgrade...
Here's a chart in the Sportsterpedia that lists some compatibilities - Others can be found by looking up (in the Sportsterpedia) a particular section that describes an item and seeing what years are mentioned as functioning the same...
http://sportsterpedia.com/doku.php/s...er_parts_chart
Old 4 Days Ago
Rollbar's Avatar
Thank you,
