0 HSR42 on a 90" ?
Last Post: Merch131ho
Last Post: Four Speed
Last Post: ChrisOfTheOT
0 Mikuni HS40 flatslide
0 Ironhead questions
0 Flame's New 1989
0 WTF Happened
Last Post: Vohnsen
Last Post: Johnmotoguy
Last Post: jharback
0 started her in gear
0 super b overflow
0 Falling out of 1st
Last Post: joes95bobber
0 My 1250 to 1275 build
Last Post: Scott
2 Humble pie
Last Post: Sprtstr1200s
0 Operation Live Wire
Last Post: WI_duker
0 2020 Sportsters
  #51
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
These engines can idle as low as 7-800 rpm. Don't do that though, it's too low.
I the timing isn't right, then no, t won't idle/run properly. Thebike only needs to ve able to run at 2000 rpm to set the ignition with a timing light. A timing light s the only real way to set the timing. Static timing only gets you close. It should be 40 BTDC at 2000 RPM
If you have compression over 120 PSI on both cylinders and you have the timing set correctly and the idle circuit is working the bike will happily idle at 1000 rom.
Again, the idle speed is NOT set with the idle screw. The idle speed isset with the stop screw on the throttle.
I suspectthat if you turn out your idle screw another 3/4 turns things will change.
Old 5 Days Ago
4th of July's Avatar
4th of July 4th of July is offline
Sportster/Buell Model: XLH 1000 cc
Sportster/Buell Year: 1976
4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light
Again, thanks for sticking with me on this. Most of you guys, if not all way above, are above my technical level on these bikes. I have done some partial carb rebuilds on old Chevy Nova's but real basic stuff like replacing needle seat that controls gas flow to bowl, replacing gaskets, etc. With this bike, which is about the same age as the Nova's (73) I really don't know what I'm doing, except in principle, and don't want to mess something up in the process.
Anyway, I don't think the increased diameter fuel line did it, just temporary. Bike will start right up, run for a minute or so then shuts down. I still believe it is fuel flow. I hit the bowl with screw driver handle let it set for a bit, then it fires right back up. Before tapping the bowl like that it would not always fire right back up. FLOAT "appears" to be sticking, my best guess, which someone already said.
I put some carb cleaner/lubricator in tank, but is there something you all would recommend if I go that easy route? If not I need to disassemble this 73 Bendix carburetor. If there is any critical advice on how to do that, and then resealing it back up, please let me know. Thanks again!
Old 5 Days Ago
doodah man's Avatar
There’s really nothing to taking a bendix carb apart if you feel that’s what it needs. Way simpler than what you had on that nova, I’m sure. After all, it’s just a handful of screws. Don’t over tighten the main jet tube, it can crack the float bowl.
http://xlforum.net/forums/showpost.p...2&postcount=30
Old 5 Days Ago
I am still pretty sure it's just the needle/seat. That's probably all you need to look at inside the carb. Cheap enough to buy a replac,emt. Probably just the needle in fact. Willing to bet it's a "viton" tipped needle.
Old 4 Days Ago
Have you checked for power to the coil? (Test light)
Maybe a Circuit Breaker or something is opening up?
If it is a fuel issue it would slow and sputter to a stop, and electrical issue will shut it off clean (usually).
Old 4 Days Ago
davixlrtt's Avatar
davixlrtt davixlrtt is offline
Sportster/Buell Model: 1965 xlch
Sportster/Buell Model #2: 1991 Honda XR600
Other Motorcycle Model: 1986 suzuki gsxr 750.
davixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to behold
The float spring can be installed in such a way that it will actually cause the float to push upwards against the needle instead of acting as a helper to drop the float.
.......Davi.
Old 4 Days Ago
Thanks guys, will check it out. If I get a definite fix, will let you know. Lots of experience on here, really appreciate it.
