0 HSR42 on a 90" ?
Last Post: Merch131ho
Last Post: Four Speed
Last Post: ChrisOfTheOT
0 Mikuni HS40 flatslide
0 Ironhead questions
0 Flame's New 1989
0 WTF Happened
Last Post: Vohnsen
Last Post: Johnmotoguy
Last Post: jharback
0 started her in gear
0 super b overflow
0 Falling out of 1st
Last Post: joes95bobber
0 My 1250 to 1275 build
Last Post: Scott
2 Humble pie
Last Post: Sprtstr1200s
0 Operation Live Wire
Last Post: WI_duker
0 2020 Sportsters
  #591
Old 17 Hours Ago
Four Speed Four Speed is online now
Sportster/Buell Year: 1988
I don't think it matters Flame - mine has two shields. The metal shield still allows oil in but it should stop debris getting to the bearing.
Old 16 Hours Ago
Flame__'s Avatar
Flame__ Flame__ is offline
Artist, rider, wrencher
Sportster/Buell Year: 1989
Sportster/Buell Year #2: 1988
Other Motorcycle Year: 2000
That's what I was thinking.
Knees in the breeze.
Gamertag, PS4: Bikerdude__
Old 10 Hours Ago
iNSaNeSHaNe's Avatar
Sportster/Buell Year: 1985
I used to run no shields because they say the bearing runs freer and last longer, but tell you the truth, I cant keep a bearing in there more than a year average so not sure which works best.
My current bearing I just put in is an MTC-6009-Z2 came in a drag box so who knows.
Old 2 Hours Ago
Metal shields should be fine as they are not sealed as such and allow splash lubrication. However, when I spoke to SKF, their engineers advised me to
remove the rubber seals (2rs) on the Zipper main bearing which they felt were unsuitable inside a gearbox. There are exceptions like the sealed bearings
in BMW shaft drives, but they have special permeable seals.
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
