0 36mm Bendix too small?
Last Post: randy3934
0 36 mm zenith bendix
0 is a buell a harley
Last Post: Scott
0 Happy Birthday Iron Mick!!!
0 Suggestions on no start
Last Post: mickey t
0 Fitment between 2005 & 2006
0 Hello!!!
0 Need help with S&S GB carb
Last Post: Monte03
0 Single women, how old are you?
0 Wrong Speedometer or Speedo Drive?
0 CV carb rubber bung
0 Speedometer Wire
0 extra side lamps
0 Zenith Bendix check valve
0 Grounded
0 Seeley Ironhead race bike
0 Andrews PB+
0 Headlight burning Out (Voltage regulator?)
0 Speedometer issue
yeller1200, IronMick (77), painter (70), motobob883 (67), rickxx (65), MRCLEEN (47), Wetcheez (46), hello_shoes (39)
  #4291
Old 2 Days Ago
Momentary Specialist
Sportster/Buell Year: 96
Other Motorcycle Year: 99
Originally Posted by Scott View Post
“Engine has been gone through.” I’m sure that means different things to different people. I would expect a freshly rebuilt engine top to bottom. The seller might mean that someone took the head off and wire brushed the crud off 10 years ago.
I might look at that one as it's close by. Since it's not a running bike, I'd want to dissemble and check the engine. At least remove heads, jugs, primary and cam covers.
Sleepy Labeef rides again!
Old 2 Days Ago
You just can't trust any random engine rebuilding.
I went to see a guy about a bunch of assorted parts. Real nice guy and self claimed IH guru. He was putting an IH together, rebuilding the engine, the push rod covers were open and I took a close look, gave the pushrods a spin, and the pushrods were covered in grit.
Old 54 Minutes Ago
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Iron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant futureIron Mike has a brilliant future
https://phoenix.craigslist.org/wvl/m...983006276.html
A shop I worked at for a number of years. Everything you need to do an Ironhead tune-up.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Glamazon, Maxeffort
