0 What's up guys
0 No click
Last Post: HarleyAsh
0 1974 XLH Rebuild
Last Post: Gearhead88
Last Post: maltesefalcon
Last Post: jeffro57
0 Conversion Kit Choices
Last Post: bagster guy
Last Post: gearbanger
0 Change engine sprocket
Last Post: FrameMount1200
0 DK Custom Products License Plate Relocations
Last Post: Melnic
0 Pinehurst NC
Last Post: XL Ed
0 You can't tour on that!!!
0 FNG from Tuckasee
Last Post: PoodlePunche
0 Increase Low & Mid Range Torque w/ STOCK Exhaust! Get a Better Sound Too!
0 Primary Cover
0 cam options
0 Allegheny 2023
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: wolfryder
0 Sumped oil.
clutch spacer, clutch spacer stud, clutch stud, stud spacer
Old 18th May 2022
XLXLXL XLXLXL is offline
Sportster/Buell Year: 1973
XLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant future
Default Clutch Stud Spacer: 1.530" pn #5995, 0.040" #5996, 0.080" #5997
hello folks,
there are three different clutch stud spacers, how are we using them, and under what circumstances?
is it oversize (0.040and 0.080) or decreased sized (-.040 and -.080)?
I bought alto clutch, I measure each plate 2.45mm, and bought another brand I measure 2.35
I need to learn the combination between friction plate ad the different stud
thanks for the respond
Old 18th May 2022
Go with the standard size 1.530.
Old 18th May 2022
The different length sleeves are to adjust the pressure plate position, likely to compensate for clutch pack thickness differences.
Clutch assy/disc thickness is measured as a stack, fibers and steels together.
Converting early clutches to use sleeves is my preferred setup, as the sleeves help to get the clutch to release flat by providing a uniform clamping height. It takes a lot of the fiddlling out of clutch setup and also reduces the rotating weight of the clutch.
Old 19th May 2022
that's the idea.
noted that about "measured as stack" thx
Old 19th May 2022
these will mushroom over time.
i usually will make my own when i need them.
Old 20th May 2022
Yes the sleeves will crush so don't get manly on the nuts.
And always use new nylock nuts.
Careful making your own spacers, exact uniform length is needed, OD is critical as you do not want the sleeve to drag on the steel.
Old 20th May 2022
when you have that resource, maybe good to work on milling or lathe
thx for the advice on using the nylock nuts. it is 1/4 - 20 right?
Old 20th May 2022
Yes 1/4 x 20.
The sleeve length difference is ~half the thickness of a steel. So that gives you some wiggle room on stack height.
For when adding or removing a disc would put the stack out of spec.
Old 23rd May 2022
Yes 1/4 x 20.
okay thanks. noted.
