0 Do you run MAXIMUM PSI?!?
Last Post: Edster
7 Hello from Spain
Last Post: hoggy
Last Post: Nate.evans
0 Brake cable on 72 xlch forward controls
Last Post: shovithead
0 Timing issue
Last Post: lugster
Last Post: Slojoe55
0 THE Trainspotting Thread
0 Shotgun Porn
0 my '82 XLS Roadster project
Last Post: N-Rico
0 Let's See Them R's!!
Last Post: grako122
Last Post: Skuzeee
0 The forum got talent
Last Post: Skuzeee
0 900 heads contd..
0 Oil and smoke everywhere
Last Post: fbroos73
0 65B genr8r I hecked up
Last Post: Kaptain
0 attn DR DICK
0 Fixing a loose mirror
Last Post: Yochstein
0 Timing after dynatek 2000i install
Last Post: jordan1200
Last Post: felis
0 Oil pump working, no oil to rockers
0 project 74 sporty
Last Post: the cowboy way
0 Aligning ‘14-newer OEM exhaust?
Last Post: jzink0883
0 Front brake combination not working well. Suggestions?
0 JACKHAMMER 570 Cams!
Last Post: md1200
sflier, dubi1946, unclesumo (61), 81ironsporty (59), cheyenne71597 (58), akk (58), MDRide, JohnK (54), 86stang (53), Dusty1985 (33), evokid8 (27)
  #111
tennmoto's Avatar
tennmoto tennmoto is offline
Sportster/Buell Model: Xl1200c
Sportster/Buell Year: 06
Other Motorcycle Model: 2010 Triumph bonneville
tennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud of
One thing you can’t deny is a large inventory of used Sportsters with low prices
Even though the Sportster might be the most reliable durable model it’s hard to sell new ones with so many cheap used ones around.
I’m like most of you, I like a nice carbed Rubbermount. It’s just a satisfying ride, and an acquired taste I guess. I don’t know what the younger guys want, many don’t even want a car.
I believe HD has a secret project at least in planning stage for the Sportster, if they just gave up on the line that would be a shock
hexnut's Avatar
hexnut hexnut is offline
Sportster/Buell Year: 2014
The future looks very good for my Sportster.
Tuned by Power Vision
Supertrapp Supermegs exhaust
1200 gearing, super brace
maltesefalcon maltesefalcon is offline
Sportster/Buell Model: SuperLow
maltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond reputemaltesefalcon has a reputation beyond repute
If they stop making them there will still be plenty of clone sources to fill the gap. Harley needs to rationalize their products and cut costs if they want to survive in the long run. If a water cooled Sportster re-design would not be cost effective, then I guess they would need to pull the plug on that product line.
I do think they make a big mistake in dropping the Dyna en masse last year. There should have been a 2-3 year transition to get people used to it and feel out where the market was. After all, the FXR which it replaced; was not removed in one model year either.
दो नोत एरसे
