Last Post: spitfirechopper
0 Do you run MAXIMUM PSI?!?
Last Post: Edster
7 Hello from Spain
Last Post: hoggy
Last Post: Nate.evans
0 Brake cable on 72 xlch forward controls
Last Post: shovithead
0 Timing issue
Last Post: lugster
Last Post: Slojoe55
0 THE Trainspotting Thread
0 Shotgun Porn
0 my '82 XLS Roadster project
Last Post: N-Rico
0 Let's See Them R's!!
Last Post: grako122
Last Post: Skuzeee
0 The forum got talent
Last Post: Skuzeee
0 900 heads contd..
0 Oil and smoke everywhere
Last Post: fbroos73
0 65B genr8r I hecked up
Last Post: Kaptain
0 attn DR DICK
0 Fixing a loose mirror
Last Post: Yochstein
0 Timing after dynatek 2000i install
Last Post: jordan1200
Last Post: felis
0 Oil pump working, no oil to rockers
0 project 74 sporty
Last Post: the cowboy way
0 Aligning ‘14-newer OEM exhaust?
Last Post: jzink0883
0 Front brake combination not working well. Suggestions?
0 JACKHAMMER 570 Cams!
Last Post: md1200
sflier, dubi1946, unclesumo (61), 81ironsporty (59), cheyenne71597 (58), akk (58), MDRide, JohnK (54), 86stang (53), Dusty1985 (33), evokid8 (27)
ChicagoSlim ChicagoSlim is offline
Sportster/Buell Model: Sportster 1000
Sportster/Buell Year: 1979
ChicagoSlim will become famous soon enoughChicagoSlim will become famous soon enoughChicagoSlim will become famous soon enoughChicagoSlim will become famous soon enoughChicagoSlim will become famous soon enoughChicagoSlim will become famous soon enoughChicagoSlim will become famous soon enough
Default 1993 Rear Brake Master Rebuild
I would like to rebuild the master cylinder on a 1993 rear brake. All I'm finding on line is a complete new cartridge for at least $40.00 but all I want to replace are the rubber pieces. The piston and cartridge look fine and I don't think need to be replaced.
Any ideas of where to find the rubber bits?
doodah man's Avatar
You might give your local Harley dealer a shout, but whether they have the parts or not is anyone’s guess. Even better if you can provide them some part numbers. At least you’d be asking them about evo parts instead of our old dinosaurs!
caution! do not stop on tracks.
The parts manual lists 43282-87e which is the whole cartridge. It doesn’t detail individual seals. I might look at the local hardware store and see what they have.
sltm1 sltm1 is offline
Sportster/Buell Model: Roadster XLS 1000
sltm1 is a splendid one to beholdsltm1 is a splendid one to beholdsltm1 is a splendid one to beholdsltm1 is a splendid one to beholdsltm1 is a splendid one to beholdsltm1 is a splendid one to beholdsltm1 is a splendid one to beholdsltm1 is a splendid one to beholdsltm1 is a splendid one to beholdsltm1 is a splendid one to beholdsltm1 is a splendid one to behold
I just got the whole shiter-oo for my 79 off ebay for $20.00, put your part # up with the brake rebuild kit for your year and see what comes up....good luck. Plus the piston was upgraded from plastic to aluminum.
