Last Post: spitfirechopper
0 Do you run MAXIMUM PSI?!?
Last Post: Edster
7 Hello from Spain
Last Post: hoggy
Last Post: Nate.evans
0 Brake cable on 72 xlch forward controls
Last Post: shovithead
0 Timing issue
Last Post: lugster
Last Post: Slojoe55
0 THE Trainspotting Thread
0 Shotgun Porn
0 my '82 XLS Roadster project
Last Post: N-Rico
0 Let's See Them R's!!
Last Post: grako122
Last Post: Skuzeee
0 The forum got talent
Last Post: Skuzeee
0 900 heads contd..
0 Oil and smoke everywhere
Last Post: fbroos73
0 65B genr8r I hecked up
Last Post: Kaptain
0 attn DR DICK
0 Fixing a loose mirror
Last Post: Yochstein
0 Timing after dynatek 2000i install
Last Post: jordan1200
Last Post: felis
0 Oil pump working, no oil to rockers
0 project 74 sporty
Last Post: the cowboy way
0 Aligning ‘14-newer OEM exhaust?
Last Post: jzink0883
0 Front brake combination not working well. Suggestions?
0 JACKHAMMER 570 Cams!
Last Post: md1200
sflier, dubi1946, unclesumo (61), 81ironsporty (59), cheyenne71597 (58), akk (58), MDRide, JohnK (54), 86stang (53), Dusty1985 (33), evokid8 (27)
bad, cone, hot, ignition, timing
Old 6 Days Ago
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of light
Lightbulb Possible ignition module going bad again and throwing timing off...
I previously had a screaming eagle ignition module that after a few years or so, when module got HOT, from engine being hot, would throw the ignition timing all out of whack and the engine would sound like a sewing machine.
Took me a LONG time to figure that one out. Issues would go away after engine cooled down, and everything would run normal. Drove me nuts for a couple years figuring that out and anyone else for that matter. I always wanted a new ignition module anyways.
When I got the Daytona Twin Tech 1005S module all those issues went away for a long time, and I finally realized what the issue really was . I am wondering if the same issue is popping up again with this cone ignition module starting to go bad getting too HOT, like the screaming eagle cone module. Or maybe I just need to get it a custom map?
I just rebuilt the engine, broke in piston rings, and she loved to ride strong at 90 passing cars etc, then after slowed down or stopped at light etc, would start to run a little funny, like overheating?
Started doing this last year riding the black hills during the sturgis rally. Would sound strange like overheating, then when got back on it, more air to cool engine, then run normal again.
Previously was the screaming eagle ignition module going bad, then would always sound like a sewing machine when got too HOT riding long distances. Always thought it was pinging, detonation, low on oil, viscosity in oil broke down etc. But it ended up simply the ignition module went bad after so many HOT engine cycles over the years and it would change the ignition timing drastically when it got passed the threshold of too HOT for the module, and electronics slowly going bad.
Any one else ever have similar issues with a hopped up engine that when got HOT, ran kind of funny, then ran normal when cool?
Wandering what the life cycle of cone ignition modules may be especially with hot exhaust pipes underneath the cone area, and so many thermal cycles.
Thanks for any feedback
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
Old 6 Days Ago
hummmm?!? my compu-fire been kicking since 1975
Old 6 Days Ago
How hot rodded is your engine? Mine runs HOT, and has great mods. I've already been thru one screaming eagle ignition module from heat issues that went bad. I'm not sure if Daytona Twin tech 1005 cone is starting to do the same as last module though.
What model compu-fire are you running? I would like to look it up and check out the specs.
Thanks
Old 6 Days Ago
Get yourself some cold spray - When the symptoms occur, hit the ignition control module with some cold spray and see if the symptoms go away...
Intermittent problems require that you pin down exactly when the problem occurs so that you can actually tell if the attempted solution really solves the problem or if it went away on it's own (being intermittent)...
So try to figure out exactly what circumstances exist when the problem occurs - If you can recreate the problem, then you can test various solutions to see how they affect the symptoms when you are actually having the problem...
2 Relax
Old 4 Days Ago
the 74 ch has seen no mercy. yep, i got the scars to prove it. we made florida runs 1000 miles one way hardly ever dropping under 4k which on my gearing is 80mph, the thing will top out at 133mph @ 7.5k.
i did up the ponies a few years back with S&S wheels and y cams and bumped the compression a tad. hardly run her hard these days since i have the sport, still handles better than the sport though.
Old 4 Days Ago
Lightbulb
2 Relax
Thanks! That is actually a great idea. I usually have water on the bike when going long distances also. Or find some small aerosol freeze spray can to put in the bag also.
Old 4 Days Ago
Careful - I would NOT put water in there --- The proper cold spray will evaporate (that's how it becomes cold) and not contaminate the gear case cavity...
Use a product like this, intended for electronics:
https://www.amazon.com/Professional-.../dp/B000Z99ZCA
Careful around your fingers and hands...
Can also be used to identify heat-related coil failure...
2 Relax
Old 3 Days Ago
Lightbulb
2 Relax
Thanks... I wouldn't spray on dials or anything, just the aluminum housing with easier access to.
:xlreocks
Old 3 Days Ago
2 Relax
Or just take off the nose cone covers to ignition cone module would allow more are to cool it off t=without the covers holding in the heat.
