Last Post: Kbetts
0 It's stalkie's Birthday!
Last Post: priell3
Last Post: Yakcm2
Last Post: Jonv
0 big bore kit
0 ARCH motorcycles and more
Last Post: RDHenley
0 Un-lowering my Super Low
0 A Day in the Life...
Last Post: RDHenley
0 Indian FTR Sales
0 Hack or trike?
Last Post: RDHenley
0 signature pic
Last Post: stikflote
0 What engine oil do you use?
Last Post: Kbetts
0 '59 XLH - Speedo cable route
Last Post: Guidorey
Last Post: waiteitei
0 Cracked motor mount
Last Post: jsandidge
0 2002 sportster 1200 points conversion
Last Post: Billy1200
buddy (66), paulrainer (66), Pedrochellie, needweknow, BunnMan (48), SolariS (43), Doc69 (39), ftptptt1234 (39), dumbmxer84 (36), nhutch40 (28), XLButler (21), Ztomasc (21)
View Poll Results: What grade gasoline do you use?
Premium Gas 91+ octane 3,707 81.94%
Mid-Grade Gas 89-90 octane 311 6.87%
Regular 87 octane 383 8.47%
I mix it up, don't care, etc. 104 2.30%
Change based on the weather 19 0.42%
Voters: 4524. You may not vote on this poll
  #1791
Old 13th November 2019
I run premium. There's a Mobil gas station "mart" about a mile from my house with 91 octane (M+R/2) no ethanol. I've been seeing some detonation, the ECU (with Powervision) has the detection software but oddly doesn't have the software to pull timing. So, I've been tailoring my fuel and timing mapping around knock indications. I expect the detonation to go away when I get the top end off and tighten up the squish clearances.
I went thru the same process on my BT Evo. It also had .055" head gaskets as OE. Harley made a running change to .040" head gaskets to tighten the squish clearance to fix the detonation issues the earlier BT EVO's had. I did more, also shortening the cylinders. Here I am 30+ yrs later doing the same the same thing on my '17 Evo Sportster. My BT EVO was an '87.
The owner's manual says premium gas for the 1200 and regular for the 883 because of the compression ratio for each.
I usually run mid-grade 90 octane because that's the only octane for my non-ethanol gas available locally. While traveling away from the house, I can run 87 in my 2005 XL883 with no problem.
I'm not a "never ethanol" guy. I run 91 octane no ethanol because the station conveniently near my house sells it. Their (Mobil) premium was 93 octane with ethanol previously and I ran that. Same station where I usually fill my daily driver with "may contain up to 10% ethanol" regular.
If I knew that I could ride my motorcycle daily like I do my cars, I wouldn't sweat the 10% ethanol gas because I know it would turn-over quickly in my tank.
However, my daily schedule and the fluctuating weather keep me from riding it as much as I would like to and it may sit for weeks or months at a time. So I keep a 5-gallon can of non-ethanol in the garage to top it off with after each ride. I would rather have it sit completely full of non-ethanol, just in case.
I also turn off the Golan manual petcock about 100 yards from my house so the carb will run empty when I park it in the garage. Probably overkill, but it's easy to do and it gives me peace of mind.
That's edited but I hope not out of context. If you're not comfortable with the current ethanol added fuels that's your prerogative.
I traded in a 2002 Kawasaki Mean Streak (that I bought new in 2002) on my Sportster in Feb this year, 2019. It had 9.5:1 CR and ran on regular. It sat 17 winters, plus 2 summers I couldn't ride due to surgeries and chemo, with regular "with up to 10% ethanol" in its' (full) tank. When I traded it in it still had all its' original fuel system components, the tank had never been off to be cleaned, the fuel system (EFI) had never been apart. No problems, ever.
I could go on but that is typical of my experience with ethanol added fuels. Racing on 100% methanol (and setting up carbs and fuel systems to flow enough) is a more fun story.
jcn59 jcn59 is offline
Sportster/Buell Model: 1200
Sportster/Buell Model #2: 1200
Sportster/Buell Year #2: 1994
Other Motorcycle Model: Aspencade
Other Motorcycle Year: 1986
jcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond repute
I find that if I use non-korn-likker gas in my bikes, boats, lawn mowers and atvs, that come spring, everything starts right up & runs fine with no curse words or other issues. (Northern WI) I haven't noticed any other advantage. I suppose that if I jacked up the timing I might need the premium gas, but I don't.
Gone but not forgotten: RD 350 Yam, Kaw 3 cyl. 500, Kaw 900 Z1, 750 Honda SS, etc.
