0 V-Twin Solo Seat Plunger Kit
0 Zippers Hammer 99 kit Info
0 Zippers 1250 kit
Last Post: seajay
0 2021 HDs now Out!
0 New from France
0 New sportster in HD Research Survey
Last Post: Mr Dream Merchant
0 Cutting out at WOT
Last Post: phyhowe
0 Can I fill gas tank up to top?
0 1977 Shift shaft
Last Post: 11B40
Last Post: skien
0 83 XLH w/Velorex 562
0 Motorcycle airbag jeans
0 Reflectors...Yeah, or Neh
Last Post: Marsikus
0 Boardtracker Project
Last Post: JonesL
0 Flat Tracker Pics
5 Tire Pressure?
0 Battery
Last Post: oldboy
0 XL1200 03 changing from 29tooth to 27
0 2021s getting new MT22 ECM
0 Rear Sprocket Runout
Reynoldston (80), showmebandit (67), Hoppy1313 (67), FredrikK (65), Toejam503 (65), YO MUDA (62), Altopass (61), tim 2007xl1200c (54), w9awx (48), 3xtrastout (42)
Old 2nd November 2005
newberrykc's Avatar
newberrykc newberrykc is offline
Sportster/Buell Model: SPORTSTER 883/1200 HUGGER
newberrykc is on a distinguished roadnewberrykc is on a distinguished road
Originally Posted by rottenralph
Hey Newberry, I used a 150/80/16 on my 3.5 inch rc comp rim. AM18 supervervenom will work. This is a V rated tire and will fit. I had one the first time I did this change. Really wide, I think it will be wider than the Metz and therefore a little harder to fit but still possible.
Thanks ralph. I will look into it.. I really want a bigger tire, this is the way to go I think....Thanks for all the good info...
98 Hugger w/ 1200 upgrade, 16" apes, HHI 4degree rake mid-glide trees, etc, etc...
Old 4th November 2005
rottenralph's Avatar
Hey Jason, The make offset sprockets for this job anyway but the chain is narrower than the belt so you should be able to go with a wider tire anyway. I was originally told I need to go to a chain if I wanted a wider tire.
Ron has written an excellent how to that is for sure. I am still trying to figure out how I am going to use the carriage bolts on my struts since the holes for the mount hardware are all recessed.
Old 22nd November 2005
harleybuilder's Avatar
harleybuilder harleybuilder is offline
Sportster/Buell Model: Custom 1200custom
harleybuilder has disabled reputation
Think this mod will work on a 01 1200c?
Old 23rd November 2005
All rear components are the same so why not. I really don't think the year matters one bit. The swingarm and wheels are all the smae from late 80's to 03 I think.
Old 13th April 2006
stein's Avatar
stein stein is offline
stein is an unknown quantity at this point
Cool
Why diden`t the MOCO deliver this from the beginning, lokks much better now. Did the job last night, on my 00 xl 53C.
Hawen`t been abel to testride it yet, but shure looks great
[B]00 XL 883/1200C[/B], Mikuni HSR42, Forcewinder AC, Bassani Pro Pipes, ported heads w/1200 valves, SE 536 cams, Pingel pet cock, and Screamin' Eagle XL Pro Adjustable Ignition System. EBC floating brake rotors, from Trac-Tek,HHI 6 piston calipers front and rear, Progressive 412`s 11 1/2", and a 150 Metzler rear tire with a 3/8" spacer.(Thanks for inspiration and "how to do"on the forum)
Old 13th April 2006
stein's Avatar
Cool
Haven`t been abel to testride it yet, but shure looks great
Old 24th May 2006
Gone Gone is offline
I'm almost finished with the Dunlop 404 150/80-16 install on my 2000 XLH. Took the advice in the sticky: 3/8 spacer from company recommended and I needed 2 washers on the right side between the swingarm and the bushing. A 1-3/8 long bushing will eliminate need for washers; I'll have to check the Indy tomorrow. If he doesn't have them, they can be ordered from the spacer company.
Clearance between the belt and tire is about 1/8 to 3/16"; plenty there. I installed 2" long 7/16 x 14 bolts in the hub pulley due to the 3/8 spacer and used Locktite Red. I did have to grind the Grade 8 markings off the bolt heads; the raised markings rubbed on the shock bolt (just enough to hear them). I'll have to work on polishing the bolt heads now. The belt alignment looks right; there is no obvious misalignment that got my attention.
The wider tire did cause some problems with installing the caliper; had to take the pads out, get the bushing between the caliper and wheel, then get the axle in (yeah, I could have used a third hand). Anyway, after getting the axle in, the pads slipped in from the bottom pretty easy. Also, the axle is about 1" too short due to the washers and hub spacer; I can't get the cotter pin in the castelated nut. I'm not sure if a nylon insert locknut would give me 2 or 3 threads after torquing the nut.
The look?
http://xlforum.net/photopost/data/500/100_13371.jpg
Old 27th September 2006
I am getting ready to change out my 140/90 kenda which measures 6.25 across to a 140/70/16 kenda for the low profile mean ass look. Going to a 120/70/19 up front. Looks like I will need a new front fender. I did not have the axle problem with my 150. Must be the brand of axle you have because mine works fine.
Old 9th October 2006
trippdog trippdog is offline
Sportster/Buell Model: sportster 1200 Custom
trippdog is an unknown quantity at this point
Wink just finished mine this weekend
ok so I have a 01 1200c and I started out following the info in the sticky. I ended up mocking the bike up several times with different combos. I started out with the 3/8 pully spacer and needed 2 washers on the drive side for pully space on the swingarm. But really the issue I had was with the space in the fender. I got shorter progressive shocks and wasnt happy with the fit in the fender. I ordered a 1/4 spacer and mocked it up with one washer on the drive side. I still wasnt happy with the fit in the fender. Believe it or not I gave it a shot with no spacer and I put one washer on the left side of the bike. This combo is the keeper. spacing in the fender is fine on both sides and although the fit is tight with the belt to clear the tire it fits fine. I will add some pictures tomorrow. Looks and handles great. Oh yeah I went with the metzeler 880's and they look great. 150/80HB-16 in the rear and 90/90H-21 in the front. oh and I didnt use carriage bolts. I had chrome bolts in the fender and wanted to keep the look. so I just got thinner nuts about 1/3 the thickness of the factory nuts. I then shortened the bolts and they fit fine. overall you cant tell the bike didnt come from the factory this way. I guess that there must be differences atleast from 95 to 01 because there was way too much space with the 3/8 spacer.
Keep The shiny side up.
Shu's Avatar
Shu Shu is offline
Other Motorcycle Year: 2007
Shu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant future
PLEASE DO POST PICTURES! I have an '00 Custom that is an inch lower than stock in the rear so your results will be very helpful to me.
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
