0 Finding an accessory power source
0 Stacking the Alto Carbonite clutch !
Last Post: Bikeaholic
3 Shaky Dave Recovery
0 Swingarm bearings - boy I'm glad I looked at them
0 spark plug wire ohms
Last Post: Kbetts
0 Finally Got the Kinks Out
Last Post: Proteus
0 2.18 Gearing Ratio For 5 Spd 1200??
Last Post: vagrant318
0 Getting ready to try firing it up after a year long rebuid
0 Head bolts and conversion
0 Alarm Time Out?
Last Post: brixtonanima
0 1972 XLH question
Last Post: 1Scooter
Last Post: marksfatboy
0 Rocker cover torx
0 FS: Forward Controls (2004 - 2013 Sportster)
Last Post: wrkdWS6
0 my recent ebay purchase
0 Who Runs Turn Signals?
Last Post: Tincan
0 '86 1100 basket build
0 Rocker Lockers - Quiet Down Annoying Top End Ticking
0 Stretched Swingarm
Last Post: Racepres
0 cleaning method for cases
0 Is static timing enough?
Last Post: ccmman
0 Changing engine oil
0 su carb question
Old 24th January 2015
xlaegain xlaegain is offline
Sportster/Buell Model: Xl1200C
Sportster/Buell Year: 2014
xlaegain is a glorious beacon of lightxlaegain is a glorious beacon of lightxlaegain is a glorious beacon of lightxlaegain is a glorious beacon of lightxlaegain is a glorious beacon of lightxlaegain is a glorious beacon of lightxlaegain is a glorious beacon of lightxlaegain is a glorious beacon of lightxlaegain is a glorious beacon of lightxlaegain is a glorious beacon of lightxlaegain is a glorious beacon of light
Default 2014 HD Service Manual: Exhaust Flange Nut Torque Spec Wrong!
Has anyone else noticed the 2014 HD Service manual says 96-120 ft-lbs vs. in-lbs for the exhaust flange nut spec? I searched around but only found a thread on primary inspection cover screw torque specs. I'm not an experienced mechanic. I'm an experienced technical mgr with, apparently, an over dependence on using the manual. In my profession that's one of the ways we ensure new guys do things the same way as the old guys. Boy did it screw me this time. I got up to about 70 ft-lbs before realizing something was wrong. I may have stripped the bolts inside the heads. Dealer's going to look at it during 10k check today. I'll submit the manual comment/feedback form in the front of the book, but I thought this might be a quicker way to protect the next poor guy using the service manual to put new pipes on. Suggestions for a better post to spread the word quicker are welcome.
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
It should be obvious that such a small stud won't be 100 ft-lbs.
Folkie
South East England Riders
To an experienced mechanic, yes. To an aspiring mechanic, not necessarily. I'm just saying, using an unreliable manual is a pretty expensive way to buy experience. Maybe those of us who weren't born with that innate common sense just don't deserve to have Harley's...
Commute on a bike... turn the worst part of your day into the best part of your day.
Old 25th January 2015
splattttttt's Avatar
splattttttt splattttttt is offline
Sportster/Buell Model: SEVENTY TWO
Sportster/Buell Model #2: Seventy Two
Sportster/Buell Year #2: 2014
splattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to all
Ahhh, exhaust flange torque values... what a crock 'o poo that is.
Correct or incorrect specs has never gotten me further than a few hundred miles, before I had to go and tighten it all down again!
My method for checking to see if it's all button down right has always been the German values first. Then check with a torque wrench to see where it's at and adjust as needed.
Usually goodentight is right.
Folkie's Avatar
Brass Nut
I use anti seize and go to around 90 in-lbs. Never been a problem.
