0 Secret Australian Business
0 code p1001
Last Post: dwint
0 Removing Rear Shock
Last Post: slamtry
0 It's stalkie's Birthday!
0 Please School Me On Carbonite Clutches
0 Fuel Pump Problems
0 1983 Ironhead Sportster decisions to be made
0 Identity crisis
Last Post: Edmundas
0 Clutch squel on take off
0 valve seals?
Last Post: Len PA
0 Been riding her for a minute...
Last Post: skien
Last Post: 5mel42
0 Pistol Braces
Last Post: Eric Von Zipper
0 Chain Problems-'90XLH
Last Post: Rollbar
0 Boardtracker Project
0 Colorado Trike
0 The Hawk Final Speaks - 7 yrs in the shadows
Last Post: HawkeyeTX
0 Newbie seeks smoother ride
0 my sunday driver...
Last Post: commando57
0 Tragic MC Museum Fire
Last Post: sprink
0 1275 or 88 or 90 CID for 4-Speed
Last Post: Four Speed
jurneyman (79), AdO650 (65), xlsport (63), darth (60), mcsmokinp (56), stalkie (56), unleashed66 (55), 66xlch (55), lownslow (49), hrg (47), Ironduke (45)
Old 29th May 2019
jazzman jazzman is offline
Sportster/Buell Model: 883
Other Motorcycle Model: 101 Scout,68guzzi,250duc
jazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud of
Why are you pulling the jugs? Not that a 1250 wouldnt be good. Doesnt cost a grand tho. Little over half that.
is that just jugs and pistons?
Into Bikes!
Old 30th May 2019
Hellbent_4 Hellbent_4 is offline
Sportster/Buell Model: XLH883 Hugger
Hellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant future
Base gasket is starting to leak. I'm not worried about yet unless it really lets go. This weekend I'll pull the valve covers and change the unbrellas.
The kit is around $600 but I would need the programmable ignition module to go with it. Otherwise save $300 and just retard the timing a bit. The 883 has a different curve than the 1200, pre-ignition can be a problem.
Old 30th May 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Yes. Jugs and pistons and bronze oil pump drive gear.
I just had a stock ignition module with the SE Race Ignition Tuner for sale for $60 You could've set the timing to whatever you wanted.
Old 30th May 2019
Do remember the part # for the SE tuner? Was it for 04 to 06 years? I want to look for one interim to a Hammer upgrade and a TC 88.
Old 4th June 2019
I'm replacing my breathers now.
Just wondering, I bought new top cover gaskets from the Harley shop. They are brown and have one raised bead in the center. The ones on the bike are black and are a double lipped gasket, top and bottom, like train tracks on top and bottom.
Which should I use?
Sent from my CPH1725 using Tapatalk
Old 4th June 2019
Hippysmack's Avatar
I reuse what don't leak.
That's up to you but the train tracks are most likely aftermarket ones.
Either should work fine...
Old 4th June 2019
super duper +++1 there mr. hippy!
Old 4th June 2019
XLFREAK XLFREAK is offline
No Posts
XLFREAK is an unknown quantity at this point
The black type were an older version that were superseded by the brown type so both are OEM, I find the brown ones seal better.
Old 5th June 2019
Thanks Bored now,
I was pretty sure they'd never been opened.
I'll keep the black one anyway.
Old 6th June 2019
denguy denguy is offline
denguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond repute
Mark the top sides of the 2 installed breather bolts, remove the bolts, tap ends and plug with set screws, cross drill into center hole at top sides of bolts. Air can pass through but oil will accumulate inside bolt and drain back into motor.
