2 My 1275 Hammer Conversion..
Last Post: mrmom9r
0 Harley-Davidson Pan America
Last Post: Bow only
0 TC88A Programming Hardware
Last Post: Andy Hog
0 Options for SE a/c cover
0 2019 Sportster
Last Post: jimmyess333
0 77 XLCH oil line routing
Last Post: nychopper
0 Hi , from NZ
Last Post: xlerate
0 Rain pants
Last Post: SLW210
Last Post: Ted Town
Last Post: davidbarker8
0 Banjo bolt sizes for front brake line.
Last Post: SLW210
0 Where can i find this led Tail light ?
Last Post: SLW210
0 1980 XLH Rocker Head question
Last Post: jc1980xlh
0 Ironhead in the uk
0 Right rear turn signal out 2002 XL1200C
0 roadside belt change
Last Post: jazzman
77xlch, buell_fxr (74), Danny (63), Wino (51), no_chrome (45), USMC_Davii (43), dijitaldna (38), 08nightmare
Old 3rd November 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Khromewerks had an earlier version of slip on call the AR100. The newer HP Plus is similar to that pic but with a more open baffle in the middle that changes size with what resembles golf balls with holes.
Old 4th November 2019
sml1226 sml1226 is offline
That level of change is not what I had in mind. The change there kills off the baffle and goes to solid pipe while trying to get the butterfly out. I can’t imagine that helps performance any, though I didn’t see any numbers for the mod.
And yes, the factory exhaust, once uncorked from the emissions compliant mufflers, is very capable if finished properly. Of course, a well designed 2:1 should be capable of equaling it, as shown by the Defender. I don’t think it’s that you can’t make a 2:1 work, rather the designers aren’t pulling it off, whether that be due to aesthetics being paramount, or lack of knowledge in doing so. Pipe builders have pulled a few different mufflers out when the freedom to do anything is taken away and they are restricted to making the space they have to work in perform well.
My curiosity with something like these “muffler“ designs, is whether it would allow for a 2:1 (or even true duals) to perform better than they do without having that perfect blend of lengths and baked in anti reversion elements like header steps, assuming reversion is the issue. Cones and lollipops have numbers associated with them in multiple designs, and they have their places, but both have drawbacks. As mentioned, both sit too close to an end to be ideal.
However, I still am left wondering if something close to “perfect” would be as great with only that butterfly valve omitted, zero other changes. If it has zero effect, great, if not, then any design using those dimensions for a new pipe needs to have an obstruction of some sort to provide a similar effect. Of course, if it does have an effect, the ideal pipe would have different dimensions in order to avoid the use of such an internal device.
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
Posted to get a look at Patriot Defender construction at the merge and muffler ...
Sleepy LaBeef (July 20, 1935 – December 26, 2019) RIP
Old 5th November 2019
And I'm supposed to know you're posting that for reference... how? Especially when rather than post just a relevant picture, or include any text at all, you throw up a full quote about a mod to the muffler assembly
Old 8th November 2019
Blackbenny Blackbenny is offline
Sportster/Buell Model: Iron 883/1250
Sportster/Buell Year: 2015
Sportster/Buell Model #2: 48
Sportster/Buell Year #2: 2016
Blackbenny is an unknown quantity at this point
Thrashin supply makes big twin pipes with these. Sadly not for sporties
Huh, those are oddball pipes. Looks like there's one at the heads and one after the collector... then they stuff more A/R stuff in the muffler. Wonder how that thing actually runs.
The design of their Sportster pipe looks like it would be fairly easy to stuff one in there if you wanted to though. There's a lot of pipe between that collector and muffler
I’ve thought about it. I’ve had that pipe for 2 years now and low end feels slow. Bat outa hell at 3000 though. I’ve looked at lsr racing as well. Not sure if I want to cannibalise my pipe. Wish someone like hammer would make one that looks good is up high and performs like the defender.
SLW210's Avatar
SLW210 SLW210 is offline
Sportster/Buell Model #2: FXLR Low Rider
Sportster/Buell Year #2: 2019
SLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond repute
https://www.thrashinsupply.com/collections/exhaust
They do make Sporty pipes (mids only), I wonder if they plan an A/R version in the future?
I like to see a Dyno chart on the M8 one.
I emailed them, I'll post back if the reply.
I’m pretty happy with mine I’d like to get it on a dyno and see how it works with my hammer stuff
Old 15th November 2019
SLW210's Avatar
No plans for an AR for the Sporty.
The only Dyno charts for the M8 and other AR are pretty much well modified, not much way to tell what just the pipes are doing.
