0 75 IH Oil leaking into starter from primary side/ bendix
0 Any experience with REBUILT title?
Last Post: canoli
0 Improving Fuel Mileage
Last Post: commando57
0 Zippers 1250 kit
0 '14 Sportster Coil Leads Question
Last Post: gwd1994
0 Boardtracker Project
0 Clearance between clutch faces 1974 transmission
0 Motorcycle airbag jeans
5 Tire Pressure?
0 XL1200 03 changing from 29tooth to 27
Last Post: sleighcrane
0 Smoke and top end job
0 Colorado Trike
Last Post: Andy56
0 New from France
Last Post: 84bobber
Last Post: Antoine44
0 Sundowner seat positioning
0 v twin Crankshaft Bushing Plate Pilot and Reamer
Last Post: thecarfarmer
0 Pinion shaft roller bearing plug fit
Last Post: Jaime1840
Old 1st December 2019
inkdigger inkdigger is offline
Sportster/Buell Model: 883 Iron
inkdigger is an unknown quantity at this point
Default Can This Be Fixed. Denim Black Gloss Spots.
Is there any way to make this less prominent? I'm more of a grease monkey than a pait guy, so I am very open to suggestions. My first inclination was to carefully scuff the polished spots with some red scotchbrite in order to make it less prominent. Thanks in advance for any ideas.
Highly-Dangerous's Avatar
Check THIS out...
But it seems you´ve got the tank already off the bike, why don´t you have it repainted??
[B][COLOR="Red"]CLICK->>[/COLOR][URL="http://sportsterpedia.com/doku.php/start"]"Maintenance is as much art as it is science"[/URL][COLOR="red"]<<-CLICK[/COLOR][/B]
[IMG]http://xlforum.net/forums/attachment.php?attachmentid=20617&d=1576580635[/IMG]
Tinz Tinz is offline
Sportster/Buell Model: X1
Tinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond repute
That’s the problem with matte paint, can’t correct any damage. Repaint or polish it all to match, but it won’t be that level of gloss again. Just FYI, red scotchbrite has a grit level similar to 320, so way too course.
Is it a urethane product or spray bomb?
Whitewalls's Avatar
Sportster/Buell Year: 1971
Other Motorcycle Model: 1988 BMW K75
Whitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond repute
What is the cause of the spots? I can't tell if it's something that is scuffed on top off the finish or if it's removed finish.
If it's something scuffed on the finish I would use rubbing compound to remove it. Never Scothbrite or sandpaper. If it's caused from removed finish than it would require touch up/repaint.
It's a brand new tank, it slipped around in the shipping box and got polished against styrofoam apparently.
Sportster/Buell Model: XLH 883/1250
Sportster/Buell Year: 1991
Contact the seller, they should have packaged it better.
John
You should have said for start!!! lol
John
John
Yea, I have already done that and we are square.
