0 Finding an accessory power source
0 The huge difference 4 degrees of Advance makes ...NOT
0 Stacking the Alto Carbonite clutch !
Last Post: Bikeaholic
3 Shaky Dave Recovery
0 Swingarm bearings - boy I'm glad I looked at them
0 spark plug wire ohms
Last Post: Kbetts
0 Finally Got the Kinks Out
Last Post: Proteus
0 2.18 Gearing Ratio For 5 Spd 1200??
Last Post: vagrant318
0 Getting ready to try firing it up after a year long rebuid
0 Head bolts and conversion
0 Alarm Time Out?
Last Post: brixtonanima
0 1972 XLH question
Last Post: 1Scooter
Last Post: marksfatboy
0 Rocker cover torx
0 FS: Forward Controls (2004 - 2013 Sportster)
Last Post: wrkdWS6
0 my recent ebay purchase
0 Who Runs Turn Signals?
Last Post: Tincan
0 '86 1100 basket build
0 Rocker Lockers - Quiet Down Annoying Top End Ticking
0 Stretched Swingarm
Last Post: Racepres
0 cleaning method for cases
0 Is static timing enough?
Last Post: ccmman
0 Changing engine oil
Old 1st December 2019
Originally Posted by folkie View Post
agreed; best thing is to try it and see.
Also: This could do with a dedicated thread of its own.
+1.
Boil1337 Boil1337 is offline
Slackmaster
Sportster/Buell Model: XL883L
Boil1337 is just really niceBoil1337 is just really niceBoil1337 is just really niceBoil1337 is just really niceBoil1337 is just really niceBoil1337 is just really niceBoil1337 is just really niceBoil1337 is just really niceBoil1337 is just really niceBoil1337 is just really niceBoil1337 is just really nice
Agreed; best thing is to try it and see.
Also: this could do with a dedicated thread of its own.
Yeah, things kinda snowballed here...
Will be getting a 44 & a 45 pilot jets & a 170 & 175 main jets, go from there...
Thanks for all the advise, fellow forum folks...!
Highly-Dangerous's Avatar
SPANIARD
Sportster/Buell Model: XL 883/1275
Here ya go, check this out: http://xlforum.net/forums/showthread.php?t=642408
Start your own thread and keep us posted. Good luck.
CLICK->>"Maintenance is as much art as it is science"<<-CLICK
Old 2nd December 2019
Confused about the the need to rejet on elevation changes as when Mark, Mary and I did the C.O.B.B.run last year we saw sea level out on the Pacific coast, then 14,000 plus elevation on top of Pikes Peak a week later returning to the Midwest. Both the Sportys did just fine. Was that just a fluke?
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: FLHP
Sportster/Buell Year: 2016
Sportster/Buell Model #2: Guzzi V7 Stone
Sportster/Buell Year #2: 2013
Other Motorcycle Model: 18 Guzzi V7D / 11 Duc 696
Confused about the the need to reject on elevation changes as when Mark, Mary and I did the C.O.B.B.run last year we saw sea level out on the Pacific coast, then 14,000 plus elevation on top of Pikes Peak a week later returning to the Midwest. Both the Sportys did just fine. Was that just a fluke?
No it's not a fluke. But he "may" need to reset now anyway. And the pilot screw adjustment isn't varied by the vacuum slide so it's possible what is set at altitude might be a tad lean at sea level (for idle operation).
Yeah, we definitely need a separate thread for the carb problem. This has been going on for days.
Old 3rd December 2019
Sportster/Buell Year: 1991
Isn't the 2nd to last picture the bowl drain screw?
John
Old 20th December 2019
Slackmaster
Alright, ordered a "Tuners Kit" from CV Performance, & picked up some Iridium plugs...
Now I guess I need to go sort the wiring harness & brakes while I wait for the kit to get here...
I would really like to get the scoot all put back together & running before the new year...!
Old 30th December 2019
Slackmaster
Got the Tuners Kit from CV, installed the 44 idle & 175 main jets...
