5 RSD LED Indicator
Last Post: mk87ita
0 Random video thread.
0 Forum member mug shots
Last Post: RDHenley
0 Dynatek Ignition questions
Last Post: Mission1
0 I'm back...
Last Post: RDHenley
Last Post: RDHenley
0 A Day in the Life...
Last Post: RDHenley
0 What engine oil do you use?
0 did the quiet baffle install short shots
Last Post: b0fh
Last Post: spamer80
0 Do people notice your bike?
5 1969 XLCH exhaust question
Last Post: Coz
0 1983 XLX--Back at it
Last Post: 83XLXCT
0 compression low?
0 can you tell me why?
0 Mid or forward controls.
Last Post: Bigshankhank
Last Post: unleashed
0 93 Sporty Key replacement
0 4 Speed Stator Replace
0 Spokes or Mags
0 Clutch Squeal
Last Post: FiftySixer
  #51
Old 30th March 2020
Is the "Judder" assembly (3 parts) equal to one Energy friction ?
Does Not seem correct
Yes. The 2 "extra" spring pieces sit "inside" the inner diameter of the "thin judder friction". The "thin judder friction" is "thin" because it has a bigger ID. The friction surface is thinner radially.
Old 30th March 2020
rocketmangb's Avatar
OK,but how does it dampen if it dont compress ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 30th March 2020
Bluto Bluto is offline
One of the parts IS a spring and does compress...
Old 30th March 2020
In service, the 2 spring pieces compress down to the thickness of the "judder friction". The "judder friction" and the 2 spring pieces add nothing to the pack thickness when the spring is compressed.
I'm not sure "dampen" is the right term. It keeps a little pressure on the clutch pack (emphasis on little) to keep the plates from chattering/screeching. I know when mine would screech I could feel the plates chattering thru the clutch lever.
Old 30th March 2020
OK
Has a belleville
Old 31st March 2020
Mark Jags's Avatar
Mark Jags Mark Jags is offline
Mark Jags is on a distinguished roadMark Jags is on a distinguished road
What exactly did you order? Just the thin friction and the two judder spring parts?
You can use the your E1 discs and plates. The thin judder spring friction plate will replace one E1 friction but you still need a steel to replace the one junk E1 steel you posted pics of.
I ordered the 2 judder spring parts, thin friction disc and 2 OEM plates, assuming I'm going to reuse my original friction discs and plates.
Old 31st March 2020
If you're going to use your original clutch pack minus the grenade plate that's exactly what you want.
Thanks to Bluto for laying this out for us!
