Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Custom Finishing
0 Mid or forward controls.
Last Post: Stray Cat
0 What makes a Hugger a Hugger?
Last Post: Hellbent_4
Last Post: Reverend G
0 Steering stem too short for tapered bearings, convert to balls?
Last Post: tiderider
Last Post: BWP 5p
0 primary chain adjustment
Last Post: RandallM
0 Did something silly maybe?
0 S1 Buell chop
Last Post: joezx10r
0 Rocker cover screw seals
0 Ignition timing vs vacuum recommendations.
10 Future hardtail springer.
0 ImgBB stopped working for me
Last Post: CT XR rider
Last Post: Diogenes415
0 Scorpion battery
Last Post: The Doctor71
0 How to jumpstart a motorcycle
Last Post: adri
0 2007 1200 low idle when hot...
Last Post: Andy56
0 Helmet poll
0 Clutch Stud Spacer: 1.530" pn #5995, 0.040" #5996, 0.080" #5997
Last Post: XLXLXL
0 ***DK Custom-2 NEW Contests-Instagram & Twitter***
Last Post: hannamontana
0 Top end tapping products
Last Post: RandallM
Bartman (58), nhfdias (52), suarezrh (47), Dash (41), x_Dj_x (40)
Old 25th November 2012
Onthisone Onthisone is offline
Sportster/Buell Model: 2001 buell x1
Sportster/Buell Year: 01
Onthisone has a spectacular aura aboutOnthisone has a spectacular aura aboutOnthisone has a spectacular aura aboutOnthisone has a spectacular aura aboutOnthisone has a spectacular aura aboutOnthisone has a spectacular aura aboutOnthisone has a spectacular aura aboutOnthisone has a spectacular aura about
Default Can the enine be cleaned and painted with out the heads being removed
Wondering is I can paint enine with heads still on or should I break down and if I break down is it easy to do and the reinstall. The engine is already out cam cover off. Please help
Hook Hook is offline
Sportster/Buell Model: 883R gone 1200R
Sportster/Buell Year: 02
Sportster/Buell Model #2: XB12R
Sportster/Buell Year #2: 07
Other Motorcycle Model: FXDXT (t-sport)
Other Motorcycle Year: 01
Hook is a jewel in the roughHook is a jewel in the roughHook is a jewel in the roughHook is a jewel in the roughHook is a jewel in the roughHook is a jewel in the roughHook is a jewel in the roughHook is a jewel in the roughHook is a jewel in the roughHook is a jewel in the roughHook is a jewel in the rough
You can always just be careful and spray paint the engine, use high temp engine paint, but for best result I would break it down and have it powder coated, last longer and more durable
Hook: 07 XB12R,02 883R,01 FXDXT
JackFrost71 JackFrost71 is offline
Sportster/Buell Model #2: Help S3T
Sportster/Buell Year #2: 2000
JackFrost71 is on a distinguished roadJackFrost71 is on a distinguished roadJackFrost71 is on a distinguished road
Yes it's possible, I've seen several on here and on chop cult. Try doing a search for for barbeque (bbq, oven, high temp) paint etc. Also called murdered out or blacked out sometimes. I've seen some good looking examples and some that may convince you to go another route. The black bike bible thread may have several.
18Bravo 18Bravo is offline
Sportster/Buell Model: Infidel Chopper
Sportster/Buell Year #2: 2002
Other Motorcycle Model: Triumph Daytona 675R
Other Motorcycle Year: 2014
18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold
Even though your motor is already out, you don't need to remove it to paint it. I did this one with barbecue paint in 86. Painted the motor and frame without removing it.
Old 26th November 2012
Does anybody have videos or pics of prepping and painting there engine?
Mosey Mosey is offline
Sportster/Buell Year: 1982
Other Motorcycle Year: 1976
Use plastic bags to mask large areas. Vaseline can be put on small parts to protect from overspray. The VHT spray paint with ceramic holds up to heat well.
That is what is called a rattlecan rebuilt motor. BTW, none of my bikes have engines - they all have motors. Just can't get useta callin' 'em "enginecycles"!!
Lol thanks yea motor does sound more manly
Went and got my sand paper 400 800 1500 and so polish so I'm going to start with the cam cover any tips send them my way as this is my first time.
Are you painting or polishing?
Put a shot of dishwashing soap in the water and use a lot of it when sanding. It's gonna be messy! It sure is a lot easier when you can remove the parts yer polishing. Good luck and post pics.
I'm going to polish heads and covers and flat black engine with paint
