0 Torque Cones
0 Jockey Shifter on a Right Side Shift Bike?
Last Post: dodgetrucken
6 1997 Sportster S putting +4 front shocks??
Last Post: Clevspeed
0 Wet sumping?
0 Some oil issues!
0 Gave up and made a bigger fuel tank (see pic)
0 Which cams ?
0 Marshwood Vale, 17th June 2019
Last Post: gpydeski
0 Laconia Motorcycle Rally 2019
Last Post: tvon
0 Tools to Lend Out to Forum Members
0 Peak Prices on Our Passion ?
0 XLCH Deluxe option packages
Last Post: AZ66XLCH
0 will not start
Last Post: Airbozo
0 72 XLH1000 Wiring Kit
5 How do you Wash your Bike?
Last Post: Airbozo
10 New to the HD world, Ironhrad vs Shovel, whats the diff
Last Post: kristyza
0 ***DK CUSTOM-Performance Stage I Upgrade Kits for Sportsters-w/Report & Dynos***
0 ***DK Custom - Stealth Adjustable Highway Peg Mounting Kit***
0 DK Custom Speedo Relocation Kits
0 Stator wire hot!
Last Post: Oberlin
0 Leatherlyke bags 2003 vs. later?
breilly888 (67), txsporty (63), michtif (54), Rabs (46)
90ci, big bore, engine builder, hammer performance, patriot defender
Old 22nd May 2016
MatHormell's Avatar
Sportster/Buell Model: XL883R
Default HAMMERPerf 90" In the Works
Figured it was time to start a thread on my current build, got alot going on with it and to good not to share!
My bike started off as a 2002 883R
HAMMER PERFORMANCE 90ci Package, consisting of:
Cp .500 Dome Pistons with Axtel Cast Iron Cylinders
HAMMER PERFORMANCE "CRUSH 600" Cams
1.725 Ratio S&S Rocker Arms
HSR 48 Miunki
XR1200 Crank Conversion w/ case mod 34T sprocket
Case Boring for 90"
Cam Box Clearences
HAMMER PERFORMANCE Sledge + head work on SE Heads
2.020" intake and 1.630" exhaust valves
Conical valve springs
S&S Premium Lifters
07 + updated oil pump
Buell Bronze Gear
Steel Timing Cup
Barnett Clutch Hub with Scorpion Clutch
Patriot Defender exhaust
Dynatek 2000i
HAMMER PERFORMANCE Air Cleaner 3"
(I'm sure I missed some stuff)
Transmission Has Been Sent To R&D Transmission:
Having zippers billet trap door installed with better bearings, transmission race cut, shift drum modification, all their magic work.
while its apart all the parts are being R.E.M Treated and MICRO BLUE Polished.
I will be posting updates as parts come in, Currently my cases are split, my heads are with Hammer Performance, I am waiting on my crank to come off back order at the end of the month, and will be sending the cases and crank to HP to be fitted and everything cleared.
ALSO want to give a HUGE shout out to HAMMER PERFORMANCE for dealing with my shit since January on this build... I have changed my mind 5 time during the process, and made him re write my invoices multiple times, Great customer service and knowledge in helping point me in the right direction for what I was looking to do to this little beast. Cant wait til everything is ready to reassemble! looking forward to updating this thread with the progress!!
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
HAMMER PERFORMANCE .600 Cams
HSR 48 Miunki
Conical Valve Springs
S&S Premium Lifters
Dynatek 2000i
WorldWideBearings
Patriot Defender Exhaust
Old 22nd May 2016
rubine rubine is offline
Sportster/Buell Year: Bits
Other Motorcycle Model: '00
Whoop whoop! Great to see more big cube builds. Lookin forward to seeing it come together Mat. That tranny work sounds lovely!
Old 22nd May 2016
MatHormell's Avatar
Very excited to see the outcome! The transmission is most likely over kill, but I really wanted something that would shift similar to the sport bikes I grew up riding. I think this one will surpass them! Will be posting pictures of R&Ds finished product!
Old 22nd May 2016
MatHormell's Avatar
Sent from my SAMSUNG-SM-G870A using Tapatalk
Old 22nd May 2016
MatHormell's Avatar
Old 22nd May 2016
rocketmangb's Avatar
Way Overkill for for the Street !
OH HELL NO !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 22nd May 2016
majam1's Avatar
majam1 majam1 is offline
majam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant future
Thing should be an absolute beast! Good luck with the build
Old 22nd May 2016
MatHormell's Avatar
Thats the plan!! Looking to smash alot of big twins! and upset some Local Dyna guys!
Old 22nd May 2016
MatHormell's Avatar
OH HELL NO !
Just looking for nice smooth seem less shifting under any load, and she's not just for the street
Old 22nd May 2016
MatHormell's Avatar
