3 So here's the idea... (for a chopper)
Last Post: Holytown
0 Operation Argument aka Big Week
0 Hello from NY
Last Post: XL Ed
0 Do you think is normal this fuel pump noise?
Last Post: hexnut
0 Trackday Sportster
0 THE Trainspotting Thread
0 And so it begins......
Last Post: Rossline
Last Post: Blowupster
0 1965 Ironhead in CT
Last Post: Moon Wolf
0 Mag wheel corrosion
Last Post: Thyratron
0 Mainshaft- What happened here
Last Post: shaymus
0 Forum problems???
Last Post: CMCSSeabee
0 85 clutch adjustment woes
0 Rubbermount shocks on a rigid mount?
6 Is Your SPORTSTER...
Last Post: Magneto Sportster
0 Who's still riding???
0 62 xlch
Last Post: oupa
0 12" or 14"? (Apehangers)
0 Spokes or Mags
Last Post: Desertfox
0 XR1200 belly pan on an XL?
cbsportster (68), sjeccles (51), 2011_Nightster (51), reeb (48), Maff (48), jl_rotary (41), UMLsilva (33)
Old 13th May 2011
Phillober's Avatar
Sportster/Buell Model: XL1250
Sportster/Buell Year: '02
Thumbs up Phillober's 1250 Conversion thread (pic heavy)
Maybe a little too heavy, I tried to snap a pic at every step of the way and I may have gone overboard, I have 96 to post of what I've done so far.... you'll just have to suffer
I know this may be boring for some but when I was looking into doing the conversion I loved these pic threads, hopefully someone will find it useful
Ok enough of my yappin'... on with the goodness:
NRHS goodies: 1250 kit, .536 cams, Twin Tech ignition and single fire coil, the heads are getting stage 2 light treatment
gratuitous bike shot before removing the saddlebags and seat
removed the battery
removed A/C and back plate
then pulled off the carb, it just pulls straight out of the manifold, no bolts or anything, there are 2 black rubber hoses that connect to it, one pulls off straight, the other requires a screw driver
I didn't bother unhooking the throttle cables, just placed the whole assembly on a chair
here is what lies behind the carb, the manifold (with my white rag stuffed in it, this is done to prevent things from falling into places we don't want)
taking the tank off, just a bolt like this one at the front and another at the back of the tank, then a ground wire that bolts to the frame under the seat, and unhooking a couple of tubes
and the tank is off
Then I just laid it on the ground on a rug, it is about half full but doesn't leak (at least not yet)
Last time I took the tank off I put it back on before putting the bolt that holds the ignition on, my bolt is a bit long so I couldn't get it in there, had to use a zip tie to keep the ignition in place I hope I remember this step this time
Old 13th May 2011
Phillober's Avatar
This is looking from the right side of the bike, (notice the manifold) I am pointing to the VOES
and it just slides right out (I did drop a washer though... I'll have fun finding out from where when I put everything back together )
and it is connected to the frame from just above where it sits
and this is a VOES
Here's the other side of what the VOES sits into, taking off the motor mount here
motor mount gone
Taking off the exhaust now, just 2 nuts for each pipe at the heads, they are sort of at an odd angle, not the easiest to take off but also not the hardest, each pipe also has a bolt on the other end of the pipe securing it to the motor, newer models may vary
and then it pulls straight out, same for both pipes
time for the jack, I have to becareful of the sharp edge that runs along the bottom of the frame, I put the jack just to the right of it
when I jacked up the bike I also had to jack up the carb not a big deal
all jacked up, secured and stripped (mostly) time to get to the good stuff
Old 13th May 2011
Banned
Where is that popcorn eating smilie when I need it
Old 13th May 2011
Phillober's Avatar
Now for the rocker box covers, I started with the rear since I knew that was the harder one to get out due to frame clearance....just 4 bolts and the top and middle covers come right off, however this bolt is the most troublesome since the frame sits almost directly above it, hard to get at it straight but take some time, it does come out
then you wiggle the top cover a bit
and then out it comes from the right side
and the middle comes out even easier
To get the bottom one off they say you need to rotate the rear wheel to close the valves (pics of that to come) in order to do this you must unscrew your plugs,
Here is the lower rocker box cover with all 9 bolts holding it in
here's just a leaf that fell in the hole in the center of the covers
See that big spring looking thing in the back? well when you turn the rear wheel those move up and down, it's easier to get the cover off if they are as far down as they can be, this is why you rotate the rear wheel
infor from steelworker: "Both pushrods should both be at their lowest position, so pressure is off the valve springs. At this point, the piston is at or near top dead centre on the compression stroke" ...... push rod pics are a few pics down
here's just a comparison shot of the 2 springs (valve springs) you can see how one is higher than the other
here's a push rod, they sit on the other end than the springs (push rods have the red stripes around them, 3 stripes on the rod closest to the exhaust side, 1 stripe for the rod on the intake side)
Last edited by Phillober; 14th May 2011 at 21:25.. Reason: added info from steelworker
Old 13th May 2011
caain's Avatar
caain caain is offline
Sportster/Buell Model: XL883L
Other Motorcycle Model: FXDB
Other Motorcycle Year: 2007
caain is just really nicecaain is just really nicecaain is just really nicecaain is just really nicecaain is just really nicecaain is just really nicecaain is just really nicecaain is just really nicecaain is just really nicecaain is just really nicecaain is just really nice
Looking forward to all 96 of them! Thanks for the post!
Old 13th May 2011
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
Here you go...
Old 13th May 2011
Phillober's Avatar
Now to get at the 9 bolts that hold the bottom box cover on, once again the rear under the frame is just in an awkward spot so it takes a bit more time but it'll come off, the manual didn't mention anything about doing 1/4 turns at a time or whatnot, but if you pay attention you will see part of the cover rise up as you take out the bolts... so doing it evenly may be a good thing
for the rear cover, taking out the push rods is a must to get the cover off, they just pull straight out
Now looking back at the springs again you can see I'm lifting the rocker box over them and sliding it out... easy sleazy
and here is the top of the head, notice the leaf from above
now the bolts I'm pointing to are the ones the manual says to loosen 1/4 turn at a time in a specific pattern, there's 4 per head and damn if they weren't stuck in there good
Here's the bolt pattern from the book
Here I am working my @$$ off to get the first one going... wasn't very easy at all!!!
then when I get to bolt 3 I have no room to work with!!!!! so I say F this noise, there's gotta be a better way.. let me emphasize what a pain in the neck these bolts were to even get to budge
So hard I lost my only 1/2" star patterned ratchet head
Couldn't believe I only had one, but that's ok, went to the hardware store and found this bad boy!
BAM this breaking bar made short work of those pesky head bolts, don't know how I've gone this long without one
Old 13th May 2011
Phillober's Avatar
When I went to pull the bolts out finally I got scared. I thought I broke the bolt in the cylinder!!!!
but no, such a relief... the threads are on the inside
Here's taking off the manifold, that 'Z' shaped wrench I got on amazon for $13 or so, it's called a manifold wrench and is made just for this purpose. I bought it cuz I didn't want to get to this point and have to wait
manifold off
Then the head just comes off... it was a little sticky, book says not to pry it off, hit it with a soft hammer, it didn't take but a tap
sans the head
these are the push rod covers, they just pull straight out (on the other head they actually stuck to the head as I pulled it off )
here's what it looks like in the push rod cover base, those paper clip looking things, that's the top of the tappets, one tappet sits in each hole underneath the push rod for a total of 4, (more of them to come later)
Ok now back to the cylinders, here's a shot of one, for all you pro's how does this look?
shot of both
Old 13th May 2011
HellHammer132's Avatar
HellHammer132 HellHammer132 is offline
Sportster/Buell Model: 883C
Sportster/Buell Model #2: 883H Led Sled Hardtail
HellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to allHellHammer132 is a name known to all
Awesome I am so pumped to do my conversion now! Keep these pics coming!
eff snow
Old 13th May 2011
Phillober's Avatar
Here's just some more shots of the head, the top
the bottom
Here's what it looks like from the bottom of both as they sit on the bike, I'm pointing to the spot where the manifold/carb would sit
That makes this the intake port/valve
and this the exhaust port/valve
since it sits next to.. you guessed it, where the exhaust connects
and the push rods are similar, I know that was boring for a lot of you but there was a time when I would read tech info and they would refer to intake/exhaust and I didn't really know what they meant, and I bet there are others who don't... but now I do
ok back to the meat
the cylinder, just like the head comes off with a slight tap if needed, just slides over the studs
and here, without the cylinders, you can see the pistons
Here's the drawing of the piston assembly, 3 is the retaining clip rings (also called circlips), 4 is the piston pin, sometimes called wrist pin, and 6 is the piston
The next step is to remove all 4 retaining clips (circlips) in order to slide the wrist pin out and the piston will come off.... be sure to put rags in the engine holes because these things can go flying and you don't want them down in the engine case
here's a close up of the wrist pin with the retaining clip/circlip, if you look at the bottom of the hole where there is a dip/groove you can see the metal ring (compare with pic below)
Books says place an awl in the groove and pry out the ring, all I had were blue jays and a screw driver
it was tricky, had to wedge 2 screwdrivers in there at times to get it out, but it came, 1 did go flying but landed in my lap, here's the retaining clip, you can now see in that groove/dip where the clip used to be
