5 Run/Turn/Brake light problems
Last Post: Meko1250
5 Terminology Sticky?
0 Sign of getting old...
0 gas tank paint protection
0 If you don't bring closure to your thread, then the terrorists have won
Last Post: Firehawk
0 12" or 14"? (Apehangers)
Last Post: Nrg2brn
Last Post: Jarlaxle
Last Post: oupa
0 Mainshaft- What happened here
Last Post: moparnut360
0 whats your iron head worth
Last Post: Whitewalls
Last Post: retread08
Last Post: Mr Dream Merchant
6 Is Your SPORTSTER...
Last Post: oupa
Last Post: Kbetts
Last Post: oupa
0 How much should I offer for this 48
Last Post: oupa
5 my 3D printed turn signals.. what would you print?
Last Post: oupa
0 How to start a 1967 Sportster XLCH
Last Post: mjdart
0 Spokes question
pwssr, petefwa, skeeter883 (67), roadogette (66), khaskins (61), iriegnome (54), sportster808 (51), ironheadmax (49), matt275 (44), DJb (43), HDFirefighter (37)
90ci, big bore, engine builder, hammer performance, patriot defender
  #1531
Old 8th August 2018
cycowrencher's Avatar
cycowrencher cycowrencher is offline
Other Motorcycle Model: 1984 KX 125
cycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud of
You're better off reducing the base gasket height.
Sent from my LGLS992 using Tapatalk
USN 1991-1995 VFA-81/ USS Saratoga, Iraq 1, Kosovo/ Bosnia Conflict
Old 8th August 2018
MatHormell's Avatar
MatHormell MatHormell is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: Buell XB12R
Other Motorcycle Model: Yamaha
MatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond repute
Yea I could go with either, running 0.020 base currently.
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
Axtel Cast Iron Cylinders
HAMMER PERFORMANCE .600 Cams
1.725 Ratio S&S Rocker Arms
HAMMER PERFORMANCE Intake Manifold
HSR 48 Miunki
XR1200 Crank Conversion W/ Case Mod 34T
HAMMER PERFORMANCE Sledge+ Head Work
2.020" Intake and 1.630" Exhaust Valves
Conical Valve Springs
S&S Premium Lifters
HAMMER PERFORMANCE Billet Push Rod Bases
Barnett Clutch Hub With Scorpion Clutch
Dynatek 2000i
R&D MOTORSPORTS- TRANSMISSION WORK-REM ISF
WorldWideBearings
Patriot Defender Exhaust
Old 8th August 2018
mac93 mac93 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 95
Originally Posted by MatHormell View Post
I have a few changes in the works.
First and foremost I have to repair my tail section and build a better support system to hold it.
I also need to design and build/ weld mounts for a chain guard, going to hang it from the frame, rather than mount it to the swing arm.
I am also thinking I am going to do some testing on the motor. I am going to swap out the 1.725 high ratio roller rocker arms from the exhaust valves and run standard ratio on Exhaust and the high ratios on Intakes. This is just for testing purposes to see what kind of difference it makes.
In addition to the standard ratio arms on the exhaust valves, I am going to drop my head gasket down a size from the current 0.030 to a 0.020. My squish was between 0.045 and.043 in most places so looking to tighten that up closer to .030 and get a small compression bump out of it.
Other things in the works for the near future is a 32T aluminum crank sprocket to get my final drive ratio closer to where I am wanting it. Hopefully I can get cracking on all this very soon, plans to be ready to TNT by mid September and make the Last Bowling Green AMRA Race.
If I’m breaking mounts I would check the crank runout. I’m running somewhere around .035/.038 squish. Was thighter last year but found the piston rock might have an issue so backed it off .010 and coated the piston skirts. Looks good so far. Seems like you can get a tighter squish with the 1250 bore/aluminum cylinders. I ran really tight with that set up, gotta warm it up good tho. Curious to see how much piston rock you have after running it in.
Old 8th August 2018
MatHormell's Avatar
Yea I spoke with dan and he agreed 0.020 is to small with the cast irons but should be good with a 0.010 base and ending up with a 0.035 squish. Since its base I may just finish out the season as is, and make the engine changes this winter during down time, that way I wont be rushed and can inspect everything more thoroughly
Sent from my SAMSUNG-SM-G890A using Tapatalk
Old 8th August 2018
MatHormell's Avatar
I'm not breaking mounts if that's what you meant
Old 9th August 2018
MatHormell's Avatar
Mac, How many CC of dome is your piston? and what CC are your chambers?
Considering having new pistons made this winter with a bit more dome to them, curious what your running. Mine came out to 22cc dome/ 91cc chambers
Old 10th August 2018
rocketmangb's Avatar
I think ya need mo dome Matt !
I think my 1250s are 17 with 81cc chambers
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
MatHormell's Avatar
Ya that will be the end result for sure is going with new pistons. I was playing it safe before and more focused on street and strip, but now Im planning to build for track only, Hopefully can squeeze 150 out of it with more compression, But that will be much later this coming winter.
HaHa, not going to believe this but I’m cleaning my garage and watching those boxes and that info burn on the bon fire right now! I leave it up to Aaron and Dan and just tune what they send me. If you talk to them they may have it in their records. I did write down the corrected ccp according to the formula on their website, 11.8, if that helps. That’s all I have, just a bracket guy working with what I have to give us what we need. IMO theres definitely more in the combo if that’s what you’re looking for. It’s giving us the consistency/mph we need so we’re not stepping on it.
MatHormell's Avatar
Haha, all good just kicking around ideas and options right now, motor is running awesome as is, going to finish out the season and make some adjustments this winter
