0 compression problems
Last Post: swamp yankee
0 It's Flame__'s Birthday!
0 I'm gunna need more Bourbon (pics)
Last Post: Will1250
0 Mainshaft- What happened here
Last Post: shaymus
0 A thank you
0 stress killer
0 Wanted: Sportster mid controls
Last Post: whetrick1
0 Excited to join the sportster family!
0 XT 1250 Ulysses with XR1200 heads
Last Post: Randy_rots
0 Rubbermount shocks on a rigid mount?
0 ultima iggy,, static time vs dynamic time
Last Post: toe
0 Little Bunny Foo Foo
Last Post: slcharger
0 What would you ask the Sportster Engineers/Designers?
0 Motorcycle Events
0 my build in my apartment
0 So heres the plan
0 Forum problems???
0 Finding a new doctor...
0 Sportster leaking fuel from small tube underneath bike.
0 1968 xlch
Last Post: Moon Wolf
0 2-1 Header Pipes
0 Seized Oil Pump
0 Flat Tire
Closed Thread
  #31
Old 26th December 2008
Shai`tan's Avatar
Shai`tan Shai`tan is offline
Sportster/Buell Model: Sportster 1250S
Shai`tan has a spectacular aura aboutShai`tan has a spectacular aura aboutShai`tan has a spectacular aura aboutShai`tan has a spectacular aura aboutShai`tan has a spectacular aura aboutShai`tan has a spectacular aura aboutShai`tan has a spectacular aura aboutShai`tan has a spectacular aura aboutShai`tan has a spectacular aura aboutShai`tan has a spectacular aura aboutShai`tan has a spectacular aura about
Just a headsup for anyone using the Zippers adjustable pushrod covers with the adaptor blocks that is considering doing the 1250 Kit upgrade. Once I had my 1250 cylinders on, I had to mod the very bottom cylinder fin on each cylinder.... so the Zippers adaptor block fit properly.
Just a headsup. ;0)
  #32
Old 20th April 2009
steelworker's Avatar
Other Motorcycle Year: 2016
Use the (blue) silicon pushrod tube lower seals. I've found them much easier to slide over the pushrod tube.
If you do have problems with these seals, first glue the seal into the locator with just 3 or 4 drops of superglue. This is enough to hold the seal in place while you slide it down over the oiled pushrod tube.
  #33
Old 14th June 2009
xena's Avatar
xena xena is offline
Assistant Administrator
Get a Yost Manifold Wrench for the intake. It made things a helluva
lot easier for a first time DIY like myself.
Wrist pin clips: A awl works well to remove them, or a tiny
eyeglass screwdriver. As per NRHS, check, double check, and
triple check that they are seated all the way in the groove.
I needed to use a magnifier to make certain but how ever you
have to, make sure they are seated.
Also get some decent torque wrenches. I got the $100
click type Craftsman. While they're not the best out there, they're accurate
and did the job well.
Consider having NRHS (or who ever does your machine work) assemble
the pistons/rings inside the cylinders. This too made things much easier
for a first timer. If I have this bike long enough to rebuild again, I would
probably try gapping/assembling rings myself now that I'm acquainted with
the rest of the job.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams
Python 3 Slip ons
TC88A running Xena's Black Panther Map
My 1212 Conversion Thread
XL Forum Members Map
  #34
Old 14th June 2009
ReddTigger's Avatar
Originally Posted by mitch View Post
Revolution Performance handled the engine build. The person who actually built it was Dusty who is no longer there. I am currently employing the services of Mean Street Cycles in conjunction with Rev Perf for the rebuild.
Brian Nallin in my opinion is one of the best out there for this sort of thing. Especially if you live in the area. Of course I am aware NRHS is a sponsor of this site. I would not hesitate to pay them my hard earned money either if they were closer to me. Dan Dunn had patiently answered questions for me prior to my build and there site has a tremendous amount of info, Read it all before going big bore!
JUST so you're aware.. NRHS was originally NALLIN's Racing Head Service..
They're cut from the same cloth so to speak. can't go wrong with either. IMO.. but Dan has been an active help on these forums..
States I've Ridden in
71.3 hp 70.8 tq
  #35
Old 31st July 2009
Manicmechanic's Avatar
Manicmechanic Manicmechanic is offline
Sportster/Buell Model: XL 883 SOLD!!
Other Motorcycle Model: Fatboy
Manicmechanic has disabled reputation
Bump......
"Whenever I see an old lady slip and fall on a wet sidewalk, my first instinct is to laugh. But then I think, what if I was an ant, and she fell on me. Then it wouldn't seem quite so funny.” Jack Handy
  #36
Old 5th November 2009
Texas_Wild's Avatar
Texas_Wild Texas_Wild is offline
Sportster/Buell Model: 1st EVO - 883 - DEAD
Sportster/Buell Year: 1986
Sportster/Buell Model #2: Maybe some day a 1200
Other Motorcycle Model: Suzuki Bandit S 1200
Texas_Wild will become famous soon enoughTexas_Wild will become famous soon enoughTexas_Wild will become famous soon enoughTexas_Wild will become famous soon enoughTexas_Wild will become famous soon enoughTexas_Wild will become famous soon enoughTexas_Wild will become famous soon enough
Originally Posted by chrism84 View Post
ok so here is my warning and things to look out for.....if your bike was purchased used double check the parts in the bike first before you change them......my bike a 99 883 had a 1200 ignition screaming eagle 6800 rpm limit already installed before i did the conversion, and no the bike was not already conveted haha.....so i went and bought one off ebay and now it is useless.....well just a warning for used bike owners.....and any suggestions on WHY in the hell someone would do that? i mean i ddont understand it
How did you figure that out? Mine has a S.E. ignition coil too? Mine is an 86 but also 883 not converted!
Learn something new everyday and your brain won't turn to mush! :tour
My 86 has passed and it was a sad day! I will ride again but not soon enought!
Old 2nd December 2013
rider61's Avatar
rider61 rider61 is offline
Sportster/Buell Model: xlc 883/1250
Sportster/Buell Model #2: xl
Sportster/Buell Year #2: 89
Other Motorcycle Model: jon way 250
Other Motorcycle Year: 13
rider61 has a brilliant futurerider61 has a brilliant futurerider61 has a brilliant futurerider61 has a brilliant futurerider61 has a brilliant futurerider61 has a brilliant futurerider61 has a brilliant futurerider61 has a brilliant futurerider61 has a brilliant futurerider61 has a brilliant futurerider61 has a brilliant future
Default why
Originally Posted by tonyhds View Post
If you have a 04 and up...... Don't do a conversion.
You might get lucky and it may work out for you.
Do you feel lucky ?
I have an 05 883. why do you say this?
1250 conversion... Big fin jugs... 560 cams.. 30* reverse dome pistons... 61cc head work... tc 88A... cam case vent... Gabriel Hi jacker air shocks... 65 P.S.I....
Patriot Defender 2 to 1 pipes... Cv-40 carb... 45 slow and 195 main jets... E3040 K&N AC 2.25 "... 97 hp 81 tq...
Energy One clutch...
  #38
ReddTigger's Avatar
because back in 2007, there were some oil consumption issues with the rubbermounts upgrading.. these have been resolved by the vendors use of a different ring seal.
  #39
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
Several thousand miles on my 05 NRHS 1250 conversion. No issues whatsoever, tons more power and better gas mileage than stock.
Closed Thread
