0 hello from a long time lurker
Last Post: priell3
0 Hello from California
0 Looking for washer part and speedo drive info
Last Post: Johnmotoguy
0 left him stranded
6 Calling all musicians
Last Post: DirtyHarry68
0 Buying another IH
Last Post: jharback
0 TC88a DIY Power adapter ?
0 Gasket goo or not to goo
Last Post: rog
0 Gasket set recommendations
Last Post: ironkiwi
0 Clutch WILL NOT adjust to disengage!
Last Post: THEWILDONE
0 Just wanted to thank everyone
Last Post: jordan1200
0 Evolution Performance Bolt-On Big Bore Kit
Last Post: jharback
0 Scored new to me used tins
Last Post: jharback
Last Post: FreakyRF
0 vibration problem solved - CHECK YOUR FRONT ENGINE MOUNT BOLT!!
0 Handlebar diameter
Last Post: ironkiwi
0 My 1250 to 1275 build
0 1977 Ironhead big fuel tank options
0 Parts interchange (Rocker Boxes And Rockers)
0 Help ID’ing... Heads and jugs are weird?
Last Post: Bryan1976
0 The Oil Leak Rabbit Hole
0 2004 rear mast cylinder
0 25 April
Last Post: Marcos.Bonfim
0 T bars or Apehangers???
Last Post: spitfirechopper
0 THE Hockey Thread
Last Post: Airbozo
Old 4 Days Ago
sportsterdoc's Avatar
Should have no affect on Idle.
+1
The serial data connection to the TSM is to compute distance traveled for auto-cancel. The only TSM function other than turn signals is TSM position 9 output to starter relay.
Debris on VSS may cause erratic speedo.
Old 3 Days Ago
Grumpy-Biker's Avatar
Grumpy-Biker Grumpy-Biker is offline
Sportster/Buell Model: Custom 883
Grumpy-Biker has disabled reputation
Ixl2relax
Yes it is right there where you said. Thanks
SportsterDoc Thanks for adding to the elimination process. I will now check all the wiring to the CKP.
I was checking spark by cranking the bike to start .
both ignition module fire after about 10 revolution.
There seems to be a greater delay before it fires.
I'm going to check it again just to make sure that is what I saw.
I'll report later.
j
Old 3 Days Ago
This might be relavent:
http://sportsterpedia.com/doku.php/t...ynchronization
Old 2 Days Ago
Hello So the wire on the CKP are good, i have continuity from under the bit to the ignition connector.
Wires from connector to the plug for the coil are good.
I'm going to start checking the other connections.
Ixl2 relax thank for that Info I going to review it carefully.
how long should a map sensor last??/
Old 2 Days Ago
How long should a map sensor last??/
Were you able to verify whether the STOCK ICM causes the engine to run differently than the DSPT?
Your previous post seemed to indicate that both modules ran the engine the same way... That both were OK and did not produce an error code... Can you confirm?
Old 1 Day Ago
Hi Ixl2relax:
The bike starts with both stock Icm and Dspt . DSPT is alway giving me the U1255 code. No code with stock.
Next step is a test ride .
Good new the TSM works. I had taken it out of the bracket and it was laying on its side to cleaning the connection. I could not get the engine to crank to check fire. As soon put it back in place it turned over.
