0 Figure Machine external breather
0 cam lobes
0 su carb question
0 flat earther bites dust trying to prove the earth is flat
0 LIQUIMOLY oil additive whose using it?
Last Post: hexnut
0 Mid West Meet & Greet
Last Post: sprink
Last Post: oldboy
0 Is static timing enough?
Last Post: Whitewalls
0 Changing engine oil
Last Post: TUCCI
0 fork reflectors
0 Changed gas cap and experienced problems
Last Post: dayypete
0 The huge difference 4 degrees of Advance makes ...NOT
0 Throw out Bearing
Last Post: robbie202
0 Who has gone from Jackhammer 570s to Impact 560s?
0 Touring on a Hugger
0 Battery cable length
Last Post: xl883lo
0 '86 1100 basket build
Last Post: Onlybckroads
0 Leineweber camshaft
0 Plug for Siren
Last Post: brixtonanima
0 TC88a DIY Power adapter ?
41caninek1 (79), InkyDoggy (69), shepsvettes (67), outlw (48), outlaw05 (48), bklyngeezer (47), Skinn (46), theguy35 (41), IronHound (41), 2013iron883 (39), huge_midgit (33)
Hennepinboy Hennepinboy is offline
Sportster/Buell Model: XLH Sportster
Sportster/Buell Year: 1966
Other Motorcycle Model: Yamaha XJ650
Other Motorcycle Year: 1982
Hennepinboy is an unknown quantity at this point
'66 XLH, I attempted to cut a set of aftermarket drag pipe to work with HD 65230-65 mufflers. The fit was not good. I ended up purchase a NOS rear HD pipe and a good used front HD pipe. With the factory pipes everything lined up as it should.
ryder rick ryder rick is online now
Originally Posted by TUCCI View Post
My Roadster came with Short Shots and the first thing I did to it was slid in some quiet baffles. I wouldn't mind em a bit quieter but it'll do. I wish the bike woulda come with the original mufflers, Icthink the Roadster stock pipes are cool looking.
"Sticking baffles inside drag pipes is like trying to fart around a cork!"
