1 Week Ago
Posts: 71 Sportster/Buell Model: Sportster Sportster/Buell Year: 86
What next steps to take?
Removed points ignition - will not work with my compression ratio!
883 bathtub heads over 1200 Flat top Pistons.
Installed dyna 2ki, retarded plate .035 on curve 4
before ignition change I went way rich on jetting to fight heat causing detonation.
Now after ign change I am down on power, flat dull stumble from 45 to 55 mph, exhaust now sounds much different, dull now was crisp before, sounds like some one lugging a big twin.
So I am thinking it's just pig rich, but plugs don't show rich?
Right now it has 32 and 72 so I ordered a low jet kit and plan to try 295 and 68
am I going the right way? Or am I missing something?
1 Week Ago
Posts: 501 Sportster/Buell Model: XL 1200 Sportster/Buell Year: 2000 Sportster/Buell Model #2: XL 1200 Sportster/Buell Year #2: 1993 Other Motorcycle Model: H-D FLH Other Motorcycle Year: 1980
If I am not mistaken, you have the module set for 28 degrees total. You might try curve 3 if that will keep the total timing at 28. That will pick up your mid range timing so you are not running around all retarded at part throttle.
Jim
1 Week Ago
Jim
probably closer to 26 to 27 total advance where I am at, so if I switch to curve 3 that should get me about 29 to 30 max but a little steeper in the middle where my complaints are (45-55) and I will probably try this.
I just figured the jetting would be first.
Am I right that a lower flater exhaust tone would be too rich, or can slower curve/retarded cause the same sound? I know both can make performance sluggish. Before, with the points the exhaust was more sharp/ringy kinda like a 2 stroke and performance was jumpy like being in the power band all the time/spastic.
1 Week Ago
Posts: 505 Sportster/Buell Model: XLH1000 Sportster/Buell Year: 1977 Sportster/Buell Model #2: 2004 XLH1200Custom Other Motorcycle Model: 2007 FXDB Other Motorcycle Year: 2004
Having to figure out carb jetting or igniton curve is a PIA! Like a dog chasing his tail. Been there, done that. Jetting 32/72 is OK so leave it alone for now. Ignition curve - start from square 1. Satic and dynamic timing, so ya know ya got a good starting point. Advancing and retarding the ignition unit makes it harder to get it right. Now reset the curve, going down from 4 untill it runs right. That don't work out? Last but not least,THICKER HEAD GASKETS to reduce CR. GOOD LUCK!
