Last Post: JimVonBaden
Last Post: T4halo
Last Post: Brad
0 Sportster Builds
0 Ironhead engine problem?
Last Post: Congojack
Last Post: CrustyTubs
0 Tachometer Suggestions
Last Post: BigMek
0 The Strociek Project
Last Post: CT XR rider
0 72 ih stroker advise needed
Last Post: rocketnorton
Last Post: ZTatZAU
0 1968 ex barn dweller thread
0 Starter gaskets 74 XLH1000
1275, big bore kit, custom build, custom oil tank, lithium ion battery
  #1401
Old 17th September 2021
xena's Avatar
xena xena is offline
Assistant Administrator
Sportster/Buell Model: XL883 w Hammer 1275
Originally Posted by BestCoastXL View Post
So as all good things that come to pass go, the bike is back together and IT LIVES!!!
I used the BelRay products in both the Pri and the oil tank.
My buddy noticed it was quieter immediately. Could be subjective, could be adjustment of the chain, but I'll take it.
Now it's just a matter of waiting for the seat to be covered. I had a local shop add some rear bolster in behind my keister so I wouldn't slip off the seat and they used a grippier fabric for the tuck and roll center section.
I'll post a couple of pics to do with that later.
Just wanted to chime in with the realization that Sportsters are decently tough bikes and they make noise. Looking forward to the wind reduction that the new fairing provides based on a quick jaunt out with the bike.
don't stop til she's chopped
Great news! Have you installed the upgraded HD oil pump? My bike is an 04 and I just did it last weekend.
XLF Rules/Guidelines
XLF Guidelines II
Hammer Performance 1275 kit w flat tops, 2007 1200 heads with Hammer Impact Service, Hammer Performance custom billet intake manifold, Stock carb, N65C needle w 45/185 jets, K&N air cleaner, SE 497 Cams, Energy One clutch w 15% spring, Python 3 Slip ons, Dynatek DSPT-1 ignition on 28b
Old 18th September 2021
BestCoastXL's Avatar
BestCoastXL BestCoastXL is offline
Disassembly Specialist
Sportster/Buell Model: XL883L
Sportster/Buell Model #2: XL883L/1275
BestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond repute
Sure did! Video install was a breeze. It’s back there in the archives of the thread.
Decided to share a few pics and bring it up to speed. Since the bike was done and I’m hunting for a new lid, I thought I’d decorate these ones.
Also in there is a rough iPhone sketch of the seat and what it’ll look like stitched up (very rough like MS Paint rough)
Also cleaned up the wiring even more in the m unit.
Just need the seat and they’ll be sayin “there goes the neighbourhood”
"It's always either something simple or something stupid"[/COLOR][/I]
Current Build '05 XL883L -->1275 Basic Kit, Cometic Gasket Kit (THE CORRECT ONE), Colony Fasteners Kit, Extra Plate Clutch, 38tooth Primary, 07+ oil pump upgrade
D cams, Hammer Pushrods, stock heads, S&S Precision Hydraulic Lifters, CV Performance CV40 Carb upgrade with EZ-Justs and V-Ductor
Arlen Air Cleaner, DK filter relocation, DK 4 stage EBS
Custom 1-piece front fender and swingarm-mounted rear fender, paint and pinstriping (done by me)
R9 Kustoms Duffel Bag & Combustion Industries Custom sissy bar for chopped fender struts
Rick's Motorsport LiFePO4 Reg/Rec, Upgraded CE Stator & Solid Rotor
TC88A sensor harness, coil, All Balls Racing 1.4KW Starter, 4AWG feed, Antigravity Lithium Battery with Restart function
Motogadget: m-unit, motoscope mini w/gauge holder & indicators, m button, m switch minis, m lock, inverted all-in-one tail light on custom altered stock seat, Kellerman Bullet R/B/T 1000's, Speedmotoco 8" LED DRL Projector headlight
Custom powdercoated frame with internal wiring, Custom electronics & battery enclosure, Goodridge SS rear brake line
D&D Bobcat 2-1
Lowbrow Customs Pursuit Brass pegs, shifters and grips, TC Bros Fwd controls
Custom Tuck-n-Roll Seat from Tommy's Upholstery Vic BC
Custom oil tank with brass "non-vented" cap, Black braided AN6 fitting oil lines
DK Rocker Lockers (yes they work)
HP: Don' know, Don't care
Old 19th October 2021
So to close out this post on a high note, I thought it would be great to share a bit of eye candy.
Behold, I give you the 1 of 1 custom seat
For a 1 of 1 bike
Old 20th October 2021
Time to enjoy the fruits of your labor!!!!
I.B.A.#26543,
John Harper's Avatar
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
Unbelievable, what a great bike. Your bike is a masterpiece, and you deserve to be very proud. Congratulations on a job extremely well done!!!
John
Old 21st October 2021
Sportster/Buell Year #2: 2008
Not bad.
Says the guy with 2 non running Sportys.
Bet you want to do it all over again....
John
Thanks John. That’s high praise considering your work. I appreciate it.
The mark of a good seat is one you don’t have to move around in at all. Finally got that sweet point between form and function. The middle section has vinyl that’s a bit grippier. I never realized how much difference that makes with these engine kits.
Originally Posted by Turbo Sporty 48 View Post
Not bad.
Funny you mention that. I’ve been wanting to explore an (whispered) electric build. Probably something like a café style to keep the weight down and try and get the battery case to look like a v-twin. Could involve some 3d printing. I dunno just spitballing currently, but I’ll still keep the bike for braps ‘n naps
