0 1960 XLH Stroker – a 13 year journey
0 Lectron Carbs: anyone used them?
0 Sportster Builds
0 Had to wait for the snow to fall to pick up my 73
Last Post: smokey 2
0 Video - DK Custom Club - You Could Become A Member!
10 1983 XR 1000 Starting Issues.
Last Post: 84rzv500r
Last Post: andy2175m4
Last Post: Akdawg
Last Post: rsneha
0 Selling my '95 883 H in Phoenix AZ - $1,750 XLF pricing before it goes on CL
Last Post: Brad
0 Video - What Comparison Dyno Charts Would YOU Like to See?
0 Ironhead engine problem?
Last Post: Congojack
0 Video - Why Tire PSI Should Be Checked Often!
Last Post: CrustyTubs
0 Tachometer Suggestions
Last Post: BigMek
0 The Strociek Project
lineberger, 39dan (63), FstPig (62), jmdajd (58), ironhead 74 (58), erjasn84, Bada Bing (57), ottchuck (56), OutlawTexan67 (54), RAJ (48), Wintersdark (45), robychopper (45), TnsporT (44), MotoSquirrel (37)
  #931
Old 11th May 2021
carbonizedeyesockets's Avatar
carbonizedeyesockets carbonizedeyesockets is offline
Sportster/Buell Model: Sportster XL883 /1275
Sportster/Buell Model #2: Sportster XLH1200
Sportster/Buell Year #2: 2002
carbonizedeyesockets has a reputation beyond reputecarbonizedeyesockets has a reputation beyond reputecarbonizedeyesockets has a reputation beyond reputecarbonizedeyesockets has a reputation beyond reputecarbonizedeyesockets has a reputation beyond reputecarbonizedeyesockets has a reputation beyond reputecarbonizedeyesockets has a reputation beyond reputecarbonizedeyesockets has a reputation beyond reputecarbonizedeyesockets has a reputation beyond reputecarbonizedeyesockets has a reputation beyond reputecarbonizedeyesockets has a reputation beyond repute
Quite interesting.
Apologies if I missed it earlier in the tread, what are the two large diameter holes on the rocker cover? ( Or are those typical of buell covers? If so what cover them)
Old 11th May 2021
Hippysmack's Avatar
Yes, it's Buell rocker boxes.
I don't have part numbers at the moment but we do have a few pics of them installed on an XL1200R.
http://www.sportsterpedia.com/doku.p...ref:engmech05f
Old 11th May 2021
TPEHAK TPEHAK is offline
Sportster/Buell Model: 2009 Buell XB12Scg
TPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud of
Originally Posted by carbonizedeyesockets View Post
Quite interesting.
Those holes are the holes where the PCV valves are sticked in to release excessive air pressure from the engine housing.
Old 11th May 2021
cool thanks!
Old 16th July 2021
Hippysmack's Avatar
I've been charting (from parts books and others) Evo Sportster rocker boxes in the Sportsterpedia.
http://www.sportsterpedia.com/doku.p...:evo:engmech04
I've found that the 04-06 lower box was used as a replacement for select 91-03 models.
Selection is based off outside finish.
The 04 lower box (and all rubbermount lower boxes) have the extra screw boss for the plastic breather valve unit.
That also means in reverse that rubbermount owners that don't like the plastic breather valve units should be able to swap their top section for 91-03 middle spacers and top covers.
And use the pop-in rubber umbrella breather valve instead.
It'd be interesting to know if this has already been done (I assume it probably has).
