0 72 ih stroker advise needed
0 71 XLH Value?
Last Post: T4halo
Last Post: dtwaddell42
Last Post: PetesPonies
0 NOS cases
0 Allegheny National Park III
Last Post: BillPlayfoot
0 Facebook sales listing
0 Hello from CT
0 Lectron Carbs: anyone used them?
0 Exhaust compatability?
Last Post: Racepres
0 2021 Iron Butt Rally
0 Sportster Builds
0 Deer hunting at stairman's.
Greg81XLH (56), saylor01 (55), Alicia (53), latnyte (52), antonini (44)
Old 10th August 2021
Jberg93 Jberg93 is offline
Sportster/Buell Model: Xlh
Jberg93 is an unknown quantity at this point
Default Had frame and swing arm sand blasted and powder coated , now what ?
I went to install the swing arm into the frame and it's too tight . It appears powder coating is to thick . Now what
It is normal to have to clean bolt holes and threads as well as any mounting surfaces to remove any powder accumulation.
Magneto Sportster's Avatar
Magneto Sportster Magneto Sportster is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1960
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1959
Magneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond repute
You should remove all of the powder coating from the surface where the swingarm makes contact. I paint my frames and a razor blade does the trick....it should probably work for powder coat too. You will probably have to do the same in other areas as well - powder coating is thick.
"Ride 'em, don't hide 'em!"
Rear Motor mounts too, might be easier with the swing arm off. I think there is a fairly large area there that needs to be cleaned off. Metal to metal not a powder coat sandwich.
mrmom9r's Avatar
mrmom9r mrmom9r is offline
mrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond repute
If you don't remove the powder coat at all mounting points it will crumble between the mating surfaces and the fasteners will loosen up.
Makes you wonder why powder coating is considered a good thing.
84rzv500r 84rzv500r is offline
Sportster/Buell Model: XLH 1200 S
Sportster/Buell Model #2: XR-1000
Sportster/Buell Year #2: 83
Other Motorcycle Model: RZV500R/R1 hybrid
Other Motorcycle Year: 1984
84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute
yeah i gave up powder coating and went back to epoxy paint...
1999 XL 1200 Sport RX, SE 7500 ignition, SE air filter, DynoJet, K&N, Cone Engineering 2:1 pipe, Storz Steering damper, with 2012 XR1200X perf forks, 3.5 x18" wheels front and rear, Galfer stainless lines, XR1200 4 piston front calipers, 18" dunlop trailmax mission 120/90 and 140/80 rear XR1200X perf shocks with 1" lift blocks...
tit for tat
powder is like paint in many ways. for better looks and smoothness, less mils and for more protection more mils.
the acceptable standard for powder is 2>3 mils.
powder is basically paint and some are epoxy, just applied diff. if your powder is chipping off, then poor prep or cure, same as with paint.
powder must be squeeky clean, it does not have carriers to help lift contamination. by nature of the beast, the heating process causes out-gassing in a lot of materials.
just like paint, additives like prism alters it and guideline must be followed.
i have a lot of guitar parts out there and yet not one to come back, yep not a mc, but can still be abused.
http://www.pedalmastersteelguitar.co...lblue005-5.JPG
Scuba10jdl's Avatar
Sportster/Buell Year #2: 1972
Powder coating is great, especially for frames. You just have to be meticulously in masking off/blocking off anything you don't want paint on.
I block off all threads, and mask off mounting surfaces that need to be clean. Not too hard to do.
[IMG]http://i.imgur.com/Oe4Ttw0.png[/IMG][IMG]https://i.imgur.com/AFv3AMo.jpg?1[/IMG]
JonesL JonesL is offline
Sportster/Buell Year: 1971
JonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond repute
When you get that far, you'll find that powder coating makes a great insulator too.
I had a Model T frame powder coated then had to go back and spot face down to bare metal everywhere I needed to ground a headlight, tail light, battery ground, etc.
When you hear hoof beats, think horses-- not zebras.
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Done properly it looks good and is "stronger" than most paints.
But you DO need to prepare for it as others have said.
And it is harder to repair if you do chip or scratch it later on. If you decide to remove it later the sandblaster will charge you more as it will take longer.
